Posts: 2095 from 2003/6/4
DFergFLA schrieb:
Ok, guys, I hate to beat on it. But, OWB is causing me no end of problems. Lets not talk about youtube, let just talk about normal web surfing. I can't use OWB more then 10 consecutive mins without it locking the entire computer. I mean frozen, non responsive, the works. I have to hold and press the power button to reboot. I could take this if it wasn't so much. I'm not kidding, not joking. After having spent a few days getting things all worked out. I finally sat down and started doing some actual web surfing. Nothing too crazy, no youtube at all. Just Yahoo, Facebook and google/news. In the last 45min I have had OWB lock up this laptop 7 times. Each requiring a hard reset to bring back. This just can't be right. I can understand it not working with youtube and some other things. I can understand it not being the fastest. But, it literally is killing the entire OS..constantly. OWB is the only program to do this to me. Everything else I have tried has worked wonderfully.
Is it really freezing the machine or just stalling with cpu load at 100% Quite some sites have scripts that eat up all cpu time for a while. In worse cases this can take quite some time which can make you think the machine has gone tits up. But once calculations are done it comes back.
I use Oddyssey for very intensively (albeit no F*book, I am not (and will not become) a member there) and get real freezes very, very, very rarely - maybe once in two months or so. Hence I'd say stability of Oddyssey is good. What is more annoying indeed is that some sites don't worlk as expected...
__
Other thing could be the memory.: As you have 2GB instlled you have two memory modules. Are the two modules of the same brand and model? If not that can cause trouble. For testing purpose you may remove one module and check whether stability increases.
[ Editiert durch Zylesea 21.02.2016 - 14:58 ]--
