Playing Videos
    Posts: 88 from 2015/10/29
    I have put a few video files on my laptop. A couple of mpeg and a few avi. When ever I click on any of them to play them I get an error: "No hexview yet..." then the path and filename.
  • »21.02.16 - 03:15
    Posts: 2220 from 2003/2/24
    There isn't a video player on the MorphOS installation by default, due the licencing reasons, but you should install MPlayer:
    http://library.morph.zone/Getting_Started#MPlayer
    And to set it as the default player:
    http://library.morph.zone/Getting_Started#Configuring_MPlayer
  • »21.02.16 - 04:31
    I have mplayer it is in /applications/mplayer. I can open it and then play vidos in it. I follewed the instructions on the link provided. I swear I did, as best as I possibly could. I have stared at the screen untill my eyes hurt... why you ask?? Because now when I double click on a video, any video. My entire system locks up.
  • »21.02.16 - 04:46
    Weird... how about if you open the shell, and run the same line you configured to mime settings. Like:
    Run >NIL: SYS:Applications/MPlayer/MPlayer -gui 1 work:videos/somevideo
    Does it hang then? Anyway, MPlayer should be rock solid and it never has crashed on me. I'd make that memory check on your system if these problems continue...
    BTW. what kind of video you tried? Some reasonable sized which would actually play smoothly or some over heavy HD video?
    [ Edited by jPV 21.02.2016 - 09:20 ]
  • »21.02.16 - 05:18
    OK, so here is where I am at:
    I have a video file in Work:video/video.mp4
    If I open mplayer and then open this file in mplayer it plays fine.
    If I double click on the file, mplayer gui opens but nothing plays. It just says "idol" at the bottom.
    If I go to "execute command" and type "RUN>NIL:SYS:Applications/MPlayer/MPlayer -gui work:video/video.mp4" I get the message "Please insert volume RUN>NIL in any drive."
    I also tried to just start mplayer form the "execute command" by typing "RUN>NIL:SYS:Applications/MPlayer/MPlayer" and get the same error.
  • »21.02.16 - 13:01
    Hmmm... so mplayer starts at least, but what "idol"......
    You are missing spaces between RUN and >NIL: and between >NIL: and SYS...
  • »21.02.16 - 13:09
    The Clouds parted and the Angels sang!!
    I This problem has been resolved.
    Now for working on my OWB issue.... that one looks like it may be harder to fix.
  • »21.02.16 - 13:44
    asrael22
    Posts: 453 from 2014/6/11
    What was the problem?
    Manfred
  • »21.02.16 - 18:51
    I am not 100% sure. Once it was pointed out to me that I was missing some spaces in my command line. I went back and tried manually typing it all in until I got it to work. I then went back to mime types and it looked good there, with all the spaces and everything. So.. I took out the %sp at the end, hardcoded a path to a video and tried again. Now I could open MPlayer by double clicking a video file, but it always opened the same one.. :) So, the then went back and put the %sp back in, then it worked fine after that...
  • »21.02.16 - 19:01
    Maybe some spaces or other characters had gone in wrong format when copying and pasting from the browser or something like that... seems to happen sometimes when I paste text from browser to other things. Or maybe there was some extra line change or similar character at the end of the line from pasting... if that could be possible in that situation, I don't know.
    [ Edited by jPV 22.02.2016 - 08:20 ]
  • »22.02.16 - 04:14
