RMB
    Posts: 88 from 2015/10/29
    I am have a very, very, very hard time with RMB on a powerbook g4 A1138. It will work sometimes, but most of the time I just give up. When it does work I have to do the two finger touch 20-30 time, I am not kidding I've counted. Just to get it to work once. For the last hour I have not been able to get it to work at all.
  • »19.02.16 - 01:05
    TheMagicM
    Posts: 1220 from 2003/6/17
    touchpad or actual mouse?
  • »19.02.16 - 02:02
    TheMagicM
    if touchpad use two fingers at the same time. it likes it. then you'll get the rmb.
  • »19.02.16 - 02:03
    I learned to use two other fingers rather then the two I was using. So, this is much better.
  • »19.02.16 - 02:41
