Vice Emulator
    rlitt01
    Posts: 43 from 2015/7/25
    Pardon my lack of understanding of using Vice not much of gamer until latley. I have some tape and disk images. How can I use them with Vice. All I get is a loading screen with no options to choose roms.(tape/disk images).
    Powermac G5(A1047) 2.3GHz Registered MorphOS
    Powerbook G4 PowerBook5,8 1.6GHz Registered MorphOS
    Powermac G5(A1047) 2.0GHz Registered MorphOS
    Icaros Desktop 3.0GHz
  • »01.12.15 - 03:35
  • fx
    fx
    Posts: 25 from 2010/10/12
    To start a game just right click to access the menu, go to File and choose 'Autostart disk/tape image...'
    Select the game and off you go!
    If the game is on a d64-disk-image you can choose what file to load in the 'Image Contents'-group after you have selected the file, and if you want to just change disk (watching a demo or similiar) just select 'Attach disk image'->'Drive 8' and select the disk you want to insert.
  • »01.12.15 - 15:36
    Jupp3
    Posts: 1193 from 2003/2/24
    Also, if you use vice from command line, you can give the image as an argument to X64. In a similar way, you can also configure disk & tape image filetypes.
    Also, if you're using a laptop, beware that the "RMB gesture" can get the emulator stuck (although there's way to get it "unstuck" somehow by doing the same thing over and over again)
  • »01.12.15 - 21:04
