Posts: 2217 from 2003/2/24
Ginger1 wrote:
1) Is there an Alt-Tab type utility (either an option in Ambient or third party) to allow me to Alt-Tab between open windows?
Depends what "Alt-Tabbing" means...
If you just want to activate next window with alt-tab combination, set it in MorphOS Preferences -> IControl -> Hotkeys -> Active Window: Activate Next (select Sample from right side button and hit your wanted key combination).
If you want some sort of graphical menu of the opened windows then you could define "All Windows: Depth Menu" from the same settings.
BTW. you can get the same menu when right clicking the rightmost gadget on any window too.
3) Related to question 2 - I'm find it quite hard on the eyes. The text is slightly fuzzy. I think the answer to this might be "buy a decent monitor", but are there other things I can try right now to crisp things up a bit?
Change fonts to be more suitable to lower resolutions? Bitmap fonts will be better than scalable ones IMHO.
[ Edited by jPV 19.09.2015 - 19:22 ]
