WPA2 + AES/CCMP networking (editing Wireless.prefs)
    ernsteiswuerfel
    Posts: 571 from 2015/6/17
    Currently I am trying to connect to my local eduroam university network. Got some years of Amiga and Linux experience but I am new to MorphOS.
    As far as I got it there is no GUI for entering username/password/connection details in MorphOS and I have to edit Prefs/Env-Archive/sys/Wireless.prefs by hand. Well, that's ok for me.
    Is there a Shell-command to scan in detail for network parameters? I need that as my current Wireless.prefs does not work. Something like "iwlist scanning" in Linux.
  • »24.06.15 - 08:34
    Posts: 3311 from 2003/3/5
    There are no tools, but the Wireless manager does have an Arexx interface that's mostly compatible with wpa_cli & family. So you can
    rxcmd WLANMNGR_GLOBAL INTERFACES
    which will give you the interfaces list.
    rxcmd WLANMNGR_GLOBAL GET_IFACEPORT <device>
    will give you the port name to talk to an actual device.
    Then you can rxcmd the new port with typical wpa supplicant control commands, like LIST_NETWORKS, SCAN, SCAN_RESULTS, STATUS, etc. See http://w1.fi/wpa_supplicant/devel/ctrl_iface_page.html
    But the best you can do is to try to copy a working config from a machine running linux. Also, I'm not 100% sure all those auth methods are actually supported by the wirelessmanager...
  • »24.06.15 - 12:23
    ernsteiswuerfel
    Thanks for the hint! But unfortunately it didn't turn out yet...
    rxcmd WLANMNGR_GLOBAL GET_IFACEPORT bcm43xx_wl.device:0
    quits with an error message "RXCmd: wrong number of arguments".
    So I got the connection data from LUbuntu Linux 14.04 running on the same Powerbook 5.4. The data is retrieved from the config file, after networkmanager successfully connected to the university network:
    [ipv6]
    method=auto
    [connection]
    id=eduroam
    uuid=e07e6e45-9bd9-4ca7-b001-2e7bd71adb1c
    type=802-11-wireless
    [802-11-wireless]
    ssid=eduroam
    mode=infrastructure
    mac-address=00:0D:93:83:7D:A3
    security=802-11-wireless-security
    [802-1x]
    eap=peap;
    identity=username
    phase2-auth=mschapv2
    password-flags=1
    [ipv4]
    method=auto
    [802-11-wireless-security]
    key-mgmt=wpa-eap
    auth-alg=open
    Which I use in ENVARC:Wireless.prefs like that:
    network={
    ssid="eduroam"
    mode=infrastructure
    eap=peap;
    identity="username"
    psk="password"
    password-flags=1
    key-mgmt=wpa-eap
    auth-alg=open
    priority=1
    Is there any log-file written where I can check what went wrong during connection setup in MorphOS?
  • »06.07.15 - 13:57
    Cego
    Posts: 738 from 2006/5/27
    i would really appreciate an extensive WiFi manager for MorphOS. I have the same problem with my PowerBook and as a matter of fact i dont want to install linux, just to get my wifi config right. I hope that this is something thats on your todo list.
    i would even consider a bounty and donate for it.
  • »06.07.15 - 23:03
    pegasos-sigi2
    Posts: 265 from 2006/8/31
    I think you use the wrong text.
    Your text is for ipv6 (I think the MorphOS stack can't ipv6).
    Use the settings for ipv4.
    [ipv4]
    method=auto
    key-mgmt=wpa-eap
    auth-alg=open
    And use the commant "method=auto".
    [ipv6]
    method=auto
    [connection]
    id=eduroam
    [802-11-wireless]
    ssid=eduroam
    mode=infrastructure
    [802-1x]
    eap=peap;
    identity=username
    password-flags=1
    [ipv4]
    method=auto
    key-mgmt=wpa-eap
    auth-alg=open
    network={
    ssid="eduroam"
    mode=infrastructure
    eap=peap;
    identity="username"
    psk="password"
    password-flags=1
    key-mgmt=wpa-eap
    auth-alg=open
    priority=1
  • »07.07.15 - 07:03
    [quote]ernsteiswuerfel wrote:
    [quote]rxcmd WLANMNGR_GLOBAL GET_IFACEPORT bcm43xx_wl.device:0 [/quote]quits with an error message "RXCmd: wrong number of arguments".
    [/quote]
    [/quote]
    Yeah, sorry, it needs to be invoked like
    rxcmd WLANMNGR_GLOBAL "GET_IFACEPORT bcm43xx_wl.device:0"
  • »07.07.15 - 14:05
    ernsteiswuerfel
    Ok, then I get:
    WLANMNGR
  • »08.07.15 - 12:39
    ernsteiswuerfel
    Ok, after a lenghty research session on XUbuntu 14.04 (running on my Powerbook) I got working config data by fiddling with wpa_supplicant in the shell. The first entry is my Nokia smarthphone where I can share my internet connection, the second one is the university network. I copied over the config-file to ENVARC:sys/Wireless.prefs.
    update_config=1
    network={
    ssid="Call from the grave"
    key_mgmt=WPA-PSK
    #proto=RSN
    #pairwise=CCMP
    #group=CCMP
    psk="PASSWORD"
    network={
    ssid="eduroam"
    #mode=0
    #auth_alg=OPEN
    #proto=RSN
    #group=TKIP
    #pairwise=CCMP
    key_mgmt=WPA-EAP
    #eap=PEAP
    #phase1="peaplabel=0"
    #phase2="auth=MSCHAPV2"
    identity="USERNAME"
    password="PASSWORD"
    priority=1
    This config works perfectly on Linux! Unfortunately it still doesn't work on MorphOS. "eduroam" gets a blue color in the WlanManager, "Call from the grave" gets yellow or red. When I connect to "Call from the grave" it still keeps asking me my password although it is properly saved in Wireless.prefs.
    The entries commented out are parameters which were not needed on Linux. On MorphOS it doesen't seem to make a difference if they are commented out or not. Still no success...
  • »08.07.15 - 13:01
    Ok, then I get:
    WLANMNGR
    Indeed, and now you can do
    rxcmd WLANMNGR "STATUS", etc. The commands are standard wpa_cli commands. Sorry I can't help you more but I'm rarely using MorphOS these days - no time :(
    [ Edited by jacadcaps 09.07.2015 - 14:18 ]
  • »09.07.15 - 11:16
    Posts: 1521 from 2003/2/24
    I have same problem with my crappy Lumia. I get it working if I delete ENV:Sys/WLANMNGR (what is empty anyway). If it existing I cant get online with my Nokia.
    However when surfing the system freezes very soon so it is unusable atm, for me at least. Haven't tried with Android phone yet.
    I investigate it later when I can...
  • »09.07.15 - 16:40
    ernsteiswuerfel
    Many thanks for your help so far!
    is working fine. I will try to investigate further. Also I can do some testing with wpa_supplicant under Linux is this is of help.
  • »11.07.15 - 18:17
