Cannot type "@" character....
    D4Ni3L3
    Posts: 26 from 2013/12/12
    Hello folks,
    can you tell me how to type "@" character?
    I have MorphOs installed on a Mac Mini with an original italian Apple Keyboard...
    and have chosen italian keyboard preference during the installation...
    I am going nuts...
    Help me :(
    [ Edited by D4Ni3L3 04.06.2015 - 21:42 ]
  • »04.06.15 - 19:39
    NewSense
    Posts: 1618 from 2012/11/9
    Try keymorpher_v1.1 for MorphOS which should show you the key that is currently setup to use that character. Hope that helps
  • »04.06.15 - 21:01
    Jambalah
    Posts: 820 from 2008/3/30
    Hi D4Ni3L3!
    You can try to solve your problem going here:
    Keymap italiana per MorphOS
    This italian keymap was made by prof Fulvio Peruggi and cover almost all key combinations on a common pc keyboard and it should work on an Apple keyboard too. This is my idea and I can't test it since I use a pc keyboard but I saw that keys are almost similar.
    Download and install it in SYS:Devs/Keymaps and select it from System Settings/Keyboard.
    On a pc keyboard key combination is ALT+@key and I've read that it's the same on an Apple keyboard. Try it and let us know =)
    Ciao!
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »05.06.15 - 07:11
    Posts: 1095 from 2004/9/23
    Simply use Alt+Q. At least it works here when selecting an italian keyboard.
    Same position as on any PC keyboard. There is also the tool KeyShow included (Tools/KeyShow), which allows to find a key very easy.
    Geit
  • »05.06.15 - 09:44
    SoundSquare
    Posts: 1214 from 2004/12/1
    SHIFT+2 works here
  • »05.06.15 - 13:23
    Jambalah
    Italian keyboard has different symbols for keys and "@" key is on "ò" key, on the left side of keyboard:
    http://cnt.lakefolks.com/it-index.htm
    and it's the same for Mac keyboard:
    http://www.taketech.it/mac-le-scorciatoie-da-tastiera-che-dovete-assolutamente-conoscere/
    MorphOs has two "strange" things since 1.4: the keyboard layout, not italian layout, and the italia.country file, which starts week day from Sunday instead of Monday.
    That's why I use Fulvio Peruggi's file for keyboard and a modified italia.country file for days  :-)
    [ Edited by Jambalah 05.06.2015 - 16:58 ]
    Pegasos II 1 ghz
  • »05.06.15 - 13:49
    D4Ni3L3
    Geit
    Alt+Q works fine on my keyboard. :)
    Many thanks to all of you for the precious help.
    [ Edited by D4Ni3L3 05.06.2015 - 20:36 ]
  • »05.06.15 - 18:34
    D4Ni3L3
    Hello!
    I tried Fulvio's Peruggi keyboard and it works fine on my Apple Keyboard. I made some tests with a PC keyboard by TRUST and it works fine too.
    I prefer using apple keyboard because I can reset the Mac Mini with the key combination CTRL + APPLE ( on the left side ) + CTRL APPLE ( on the right side ).
    I tried the same positioned Keys on the PC keyboard and I cannot reset.
    So what can you say to me about key resetting? How do you perform it?
    [ Edited by D4Ni3L3 07.06.2015 - 20:59 ]
  • »07.06.15 - 18:58
    DoctorMorbius_FP
    Posts: 315 from 2004/2/13
    D4Ni3L3 wrote:
    Hello!
    Hello D4Ni3L3,
    with the Apple keyboard you con use LEFT CTRL - LEFT APPLE - RIGHT APPLE (no need for RIGHT CTRL), with the PC keyboard connected to the Mac Mini you should use LEFT CTRL - LEFT WINDOWS - RIGHT WINDOWS (at least I hope so: this work on a Pegasos, but is untested on a Mac Mini).
  • »07.06.15 - 22:21
    boot_wb
    Posts: 874 from 2007/4/9
    DoctorMorbius_FP wrote:
    D4Ni3L3 wrote:
    Hello!
    Hello D4Ni3L3,
    I have a PC (USB) keyboard which won't do the three fingered salute (the right windows key is replaced with a 'menu' key instead), although standard PC keyboards with two 'windows' keys do work in my experience.
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »08.06.15 - 10:57
    Raf_MegaByte
    Posts: 430 from 2004/10/10
    D4Ni3L3 wrote:
    Hello!
    Hello D4Ni3L3,
    Three fingers salute reset worked flawlessly for me on Pegasos II with Logitech keyboards sporting 2 Windows keys. (I own Logitech Desktop Wireless Navigator PS2+USB keyboard + Mouse Set, i.e. the first version that features Left and Right Windows keyx. New versions have only Left Windows key.)
    With MacMini I currently use USB cable Keyboard from HewlettPackard which has two Windows keys, and also works perfectly with MorphOS 3.8.
    [Extra:
    I advice you not to buy HewlettPackard keyboards. Mine is awful and often do not recognize key pressing, and mainly "SHIFT" key, so I must continuously edit missing upper case in capital letters.]
    [ Edited by Raf_MegaByte 09.06.2015 - 11:06 ]
  • »09.06.15 - 07:34
