Wazp3d installation
    WeiXing3D
    Posts: 327 from 2012/6/13
    I wanted to instal Wazp3d when I ralized that I need to:
    copy Wazp3D.library-morphos TO MOSSYS:Libs/Warp3D.library , and then,
    copy Wazp3DPPC.library-morphos TO MOSSYS:Libs/Warp3DPPC.library
    When I realized that I can't find thw Warp3D library in SYS:Libs/. I always assume that Warp3D was part of the normal installation of MOS, in my case 3.7.
    If I need to install Warp3D first, where I can fin the appropiate version for MOS?
    Thank you in advance for your responses.
  • »11.01.15 - 00:39
    BSzili
    Posts: 570 from 2012/6/8
    I double checked it, and the readme says nothing about any Warp3D library in SYS:Libs. Just copy the two files you've mentioned in your post, and you will be done with the installation.
  • »11.01.15 - 06:31
    Posts: 12537 from 2003/5/22
    As you wrote yourself, it is in MOSSYS:Libs/. That's where it is to be substituted by Wazp3D.
    MorphOS comes with Goa3D, which is a reimplementation of Warp3D.
    http://www.biclodon.com/software/goa/
    You don't, and nowhere is it implied that you would.
  • »11.01.15 - 07:13
