[Clock] Can't change the time
    TomKeric
    Posts: 146 from 2013/2/18
    I cant change the clock time. it is going on UK time and I need to move it to +1 hrs. the top bar flashes red when I try to change the clock.
    -If you've never failed, you've never tried -
  • »24.12.14 - 15:10
    Posts: 1368 from 2010/1/6
    SystemPrefs/Locale: Choose correct timezone for your location!
    Change time: Doubleclick on time-gadget in Ambient menu-bar, or Systemprefs/Time.....
    [ Editiert durch Amigaharry2 25.12.2014 - 10:48 ]
  • »24.12.14 - 19:02
    TomKeric
    System prefs did not contain Locale,
    System contains prefs
    in Locale could not find where to select time zone
    (I did chose correct time zone upon installation)
    I am lost ;)
  • »26.12.14 - 10:44
    Sure you're working on MorphOS? :)
    On Screenbar (Menubar) select Preferences/System and then (in opening window) Locale..........
  • »26.12.14 - 14:07
    Tom01
    Posts: 187 from 2009/9/20
    In the Ambient-Menu Settings/System/Locale/Time Zone
    The Date and Time you set in Settings/System/Time or better with SetClockNTP in S:/user-network-startup.
  • »26.12.14 - 14:12
    TomKeric
    Dear Tom and AmigaH.
    I found the time zone and it is correct set already.
    The clock however is one hour wrong. I cant change the clock on setting/system/time.
    I tried to locate the SetClock but did only find it through the utility "find" located in System:MorphOS/C/ so I opened it and then Ambient output window returned following "SetClock: required argument missing
    System:MorphOS/C/SetClock failed returncode 20"
    I think it is wierd that it should be so hard for an beginner to choose the correct time on the clock ??
    Thanks for guidance
    /Tomas
  • »28.12.14 - 17:39
    Posts: 2202 from 2003/2/24
    You were probably trying to type number there, but didn't use backspace/del to remove old number first. Clock's input string only accepts two characters and flashes if you try to type more.
    Anyway, you were in right place to change the time (on time prefs which can be found from system settings or double clicking the clock in screen bar).
    But if you happen to use setclockntp to sync clock from net and still get clock one hour off on each reboot, then you should change timezone setting from locale prefs. That may happen for example with summer/normal time changes.
  • »28.12.14 - 18:02
    TomKeric
    [Thread closed]
    Yes i didnt delete the old number, I am so used to only have to mark and enter so actually deleting them before entering new clock time was the solution.
    However I have to say that is really something that should be changed in MOS, it is just not logic for an average user of 2015 I think,
    thanks you all for your help
    Tom
  • »03.01.15 - 18:22
    Yeah, as the marking works in other places usually, I'd consider this as a bug. Maybe some limitation in MUI for certain types of input strings or so, but anyway. I made a bug report of it and lets see if it'll be changed in future :)
  • »05.01.15 - 06:49
    Jeckel
    Posts: 133 from 2007/3/11
    Maybe it should be some numeric buttons rather than text input?
  • »05.01.15 - 06:52
