[OWB] ctrl+c outside OWB shut down OWB
    TomKeric
    Posts: 146 from 2013/2/18
    if I ctrl+C outside OWB to copy this error message to the forum OWB shut down and cannot be restarted, I need to restart MOS to be able to restart OWB. Any clue why the ctrl+C gives me this outcome. ctrl+c inside OWB does not give this result
    -If you've never failed, you've never tried -
  • »24.12.14 - 15:10
    Cego
    Posts: 738 from 2006/5/27
    you dont copy with ctrl+c. you have to press rcommand+c or lcommand+c (amiga/apple/windows button on the keyboard)
  • »24.12.14 - 16:35
    TomKeric
    [+] Thanks Cego- it works with using the right command button+c om the Mac Keyboard and paste with rcommand+v.
    [-] But why does OWB lock down and cannot be restarted without reboot OS if you do ctrl+c outside OWB.
    This is naturally a typical WIN copy paste behaviour and I wonder if it makes sense that the browser is locked ? What is the purpose or is it a bug?
  • »26.12.14 - 10:53
    Raf_MegaByte
    Posts: 430 from 2004/10/10
    OWB works with Webkit HTML rendering engine so it inherits a vaste number of combinations of keys form alien operating systems.
    I think it has been made intentionally for a practical purpose.
    For example it clears the address input bar with CTRL +X combination.
    However I tried many times CTRL +C CTRL +V combinations. They copy and paste only ASCII set code.
    If I want to copy and paste international characters such as japanese, I need to use LeftAMIGA (LeftCommand) +C and LeftAmiga (LeftCommand) +V, that are able to copy all UTF8 international character set.
    Also CTRL +C CTRL +V combination leaves an obnoxious ">" character in the begiining of the copied string, that must be deleted in most occasions.
    > Copied with CTRL +C
    I mean, ">" character at the beginning it is good for quoting, but not when you need a precise cut & paste of entire string, such as in passwords.
    [ Edited by Raf_MegaByte 27.12.2014 - 11:05 ]
  • »27.12.14 - 07:57
    Cool_amigaN
    Posts: 776 from 2011/11/30
    Guys, since you are talking about shortcuts, I have a question for you all.
    I have recently purchased a gaming Gigabyte keyboard which runs nice on the PC. I wanted to test it under MorphOS too, just to check if it recognized and if yes why not purchase another one, however I discovered that it has no right windows button! It's kinda custom made for gaming purposes and only features an Fn key and a lock win key (triggered when in online gaming in order to prevent accidental press of the left windows/start button). So, is it possible to define a new RAmiga/RCommand key via a utility or something?
  • »29.12.14 - 07:02
    Posts: 2217 from 2003/2/24
    What error message you are trying to copy? Some OWB related? Did OWB open new output window? If you try to use CTRL-C on output window it tells to program owning that window to quit itself.
    CTRL-C is commonly used to quit/break/abort programs in many operating systems (Amiga, Linux/unix variants, Mac etc). Microsoft has yet again messed things up and made it working as non standard copy command :) This causes many problems on all platforms :)
    In Amiga, MorphOS, OSX etc you use command-c to copy and CTRL-C is for aborting programs. Although some programs in MorphOS give you an option to copy/paste with CTRL too, just for making Windows users more comfortable, but as seen, it may cause problems and I'm not sure if it's a good behaviour afterall. You can look for example Keyboard section in MUI prefs and see that both command and CTRL options are enabled by default with MUI programs under MorphOS.
  • »29.12.14 - 08:17
    TomKeric
    I seem to be to deeply into Windows. :)
    I can understand ctrl - c aborts OWB, but I cant understand why I cant restart OWB without restarting MOS
  • »03.01.15 - 18:11
    Maybe it wasn't OWB's output window, but Netstack's instead. If you kill Netstack it also kills OWB, and OWB won't start up without working TCP/IP stack running.
    It's an another question if OWB should be run in offline mode without TCP/IP stack, but that's not up to MorphOS, but should be asked from OWB's developer (Fab).
    In any case, MorphOS usually has TCP/IP stack running on boot, if not killed on purpose. And in this case (probably) you shoud start both TCP/IP stack (Netstack) and OWB to get in original situation and be able to browse the net again.
    [ Edited by jPV 04.01.2015 - 19:34 ]
  • »04.01.15 - 15:29
    TomKeric
    [Thread Closed]
    That truly makes sense now. I believe that is what happened.
    Thanks for clarifying jPV!
    /Tom
  • »04.01.15 - 17:20
    Posts: 1385 from 2010/1/6
    Look at USB-Prefs (If your KB is USB-type). There your keyboard should be listed (HID-class) -> double click on it opens general device information -> Keyboard should be listed at "Interfaces" -> double click opens hid-class-prefs. There take look at Keyboard and Action.........here you can redefine keys......
    [ Editiert durch Amigaharry2 04.01.2015 - 20:50 ]
  • »04.01.15 - 17:49
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    TomKeric wrote:
    [Thread Closed]
    /Tom
    I don't know what happened in your case, but Odyssey handles ctrl-c properly and just quits when triggered. And of course, it can be restarted after that (unless you don't have a large enough contiguous memory block anymore to load the binary in memory).
  • »04.01.15 - 21:19
