ed and c/c++ projects?
    trehune
    Posts: 5 from 2009/3/26
    I have a questions about ed. Is it supposed to handle C/C++ projects? If I create a new file, tell ed it's a c/c++ file, I get an extra c/c++ menu. But I can't create projects, make files, or anything else, I just get this error: Support for this compiler was not installed: gcc.
    I installed the full 2.5 SDK from Morphos site.
    /T
  • »21.06.10 - 18:43
    trehune
    Got help from #morphos:
    makedir morphed:add-ons/c++/compilers/
    makedir morphed:add-ons/c++/compilers/gcc
    Ed now works great! :)
  • »21.06.10 - 18:55
    Posts: 3300 from 2003/3/5
    Oh, sorry for that. I'll make sure this is fixed in the next SDK update.
  • »22.06.10 - 05:31
    jcmarcos
    Posts: 1178 from 2003/3/13
    Just two days after the SDK left beta status... Pity!
    Great job, by the way!
  • »22.06.10 - 10:40
    @jcmarcos
    The plan is to have frequent updates - the SDK will be updated at least with each MorphOS release.
  • »22.06.10 - 12:23
