Moderator
Posts: 2581 from 2003/2/24
Cubic uses some scripts to switch between different compilers, so calling gcc without having Cubic invoked might lead to some paths not set.
Compiling under Cubic should work out of the box, but you might want to provide extra info, like everything that was spewed into console, your compiler/linker-options (found under blue-green checkmark), did you let Cubic generate a makefile etc etc....
