Scribble 1.2
    r-tea
    Posts: 316 from 2005/3/27
    Any idea how to make Scribble 1.2 open default session at startup?
  • »07.03.14 - 18:16
    Nadir
    Posts: 178 from 2003/3/17
    Make a default project and tie a session to it in the project settings.
    /Nicholai
  • »08.03.14 - 15:14
    sarakhan
    Posts: 1 from 2014/12/10
    Now MophOS?SDK?doesn't work and it was my fault, but somebody can post the reference on startup-sequence of SDK? It lays between TurboPrint assign and AddAudioModes.
    Cut down your exam stress by using our latest cert killer and high quality 501-01 braindumps and 640-875 dumps.
  • »10.12.14 - 16:37
    pegasos-sigi2
    Posts: 265 from 2006/8/31
    1.) The MorphOS SDK isn't includet in MorphOS 3.x. per default.
    You must download and install it for your selfe.
    2.) Dont't change anything in the startup-sequence.
    It ends up in a non working system.
    ; MorphOS startup-sequence
    ; Copyright © 2002-2012 The MorphOS Development Team, All Rights Reserved.
    ; This script is executed on system boot. Do *NOT* modify this file!
    ; Use S:user-startup instead.
    ; $VER: startup-sequence 1.12
    Failat 21
    Version >NIL:
    Resident >NIL: MOSSYS:C/Assign PURE
    Resident >NIL: MOSSYS:C/Execute PURE
    MakeDir RAM:T
    Assign T: RAM:T
    MakeDir >NIL: RAM:ENV RAM:Clipboards
    Copy >NIL: ENVARC: RAM:ENV ALL NOREQ DONTOVERWRITE
    Assign ENV: RAM:ENV
    if exists SYS:Locale NOREQ
    Assign LOCALE: SYS:Locale
    if exists SYS:Locale/Help NOREQ
    Assign HELP: SYS:Locale/Help
    endif
    endif
    if exists MOSSYS:Locale NOREQ
    Assign LOCALE: MOSSYS:Locale ADD
    if exists MOSSYS:Locale/Help NOREQ
    Assign HELP: MOSSYS:Locale/Help ADD
    endif
    endif
    Assign KEYMAPS: DEVS:Keymaps DEFER
    Assign CLIPS: RAM:Clipboards
    Assign PRINTERS: DEVS:Printers DEFER
    Assign REXX: S: DEFER
    Assign MUI: SYS:Applications/MUI DEFER
    LoadMonDrvs
    if exists "MOSSYS:Devs/DOSDrivers/CON" NOREQ
    Assign >NIL: CON: DISMOUNT
    endif
    Mount >NIL: MOSSYS:Devs/DOSDrivers/~(#?.info) DEVS:DOSDrivers/~(#?.info)
    SetEnv Workbench $Workbench
    SetEnv Kickstart $Kickstart
    UnSet Workbench
    UnSet Kickstart
    AddDataTypes REFRESH QUIET
    ConClip
    Path >NIL: C: SYS:Utilities S:
    IPrefs
    if not exists ENV:NOTRANCE NOREQ
    Run <>NIL: DETACH QUIET Trance
    endif
    RexxMast >NIL:
    Assign >NIL: TurboPrint: MOSSYS:TP
    if exists "TurboPrint:configs/_Last_" NOREQ
    Run <>NIL: TurboPrint:turbo/ttp
    endif
    AddAudioModes >NIL: REFRESH QUIET
    if not exists ENV:MorphOSSDK NOREQ
    if exists SYS:Development NOREQ
    SetEnv MorphOSSDK SYS:Development
    endif
    endif
    if exists ENV:MorphOSSDK NOREQ
    Assign SDK: "$MorphOSSDK"
    if exists SDK:Startup NOREQ
    Execute >NIL: SDK:Startup
    endif
    endif
    if exists S:User-Startup NOREQ
    Execute >NIL: S:User-Startup
    endif
    Resident >NIL: Execute REMOVE
    Resident >NIL: Assign REMOVE
    LoadWB
    EndCLI >NIL:
  • »10.12.14 - 18:26
