How to create 'link files' in MorphOS?
    ausPPC
    Posts: 543 from 2007/8/6
    There are a number of these in the MorphOS SDK that just 'point' to actual files in other folders. I think they're also called 'links' under Linux and 'shortcuts' under windows and it's trivial to create them on those OSes. How are they made on MorphOS?
  • »05.01.11 - 21:27
    Posts: 12566 from 2003/5/22
    I think that's something else technically, albeit serving a similar purpose.
    http://en.wikipedia.org/wiki/File_shortcut#Microsoft_Windows
    See there for the conceptual difference:
    http://en.wikipedia.org/wiki/Symbolic_link#Shortcuts
    The same way they are made on Amiga(D)OS.
    http://en.wikipedia.org/wiki/Symbolic_link#Amiga
  • »05.01.11 - 22:17
    ausPPC
    Aha - thank you for that. I see it there in my DOS manual now but never used it before.
  • »06.01.11 - 00:06
    Posts: 3336 from 2003/3/5
    To create links just use the 'makelink' command.
    And btw, Windows has softlinks as well - in NTFS. They're called junctions. A Windows 'shortcut' isn't one.
  • »06.01.11 - 09:19
    boot_wb
    Posts: 874 from 2007/4/9
    (Seemed better to resurrect this old thread rather than create another)
    Some working around is needed to delete softlinks, as the Ambient delete buttons and context-menu commands address the softlink's target, rather than the link itself.
    Softlinks can be deleted using rm (part of the SDK), but is there anything in the default OS install which can do this, or a more obvious solution which I'm missing?
    Also, softlinks cannot be addressed opaquely using Ambient mimetypes.
    The commands "gg:bin/rm %sp" or "gg:bin/rm %sf" (+ changing working directory to current) are seen transparently, and the command attempts to delete the softlink target rather than the link itself. Is there some funky AmigaDOS pattern-matching magic I'm missing that would address the softlink rather than its target?
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »24.06.12 - 11:54
    waleed432
    Posts: 1 from 2014/11/8
    Are you shure that the compiler generates Altivec instructions with -mcpu=powerpc?
    I don'tthink so.
    We offer up to date Braindumps.com exam practice questions with self NS0-504 test engine to help you pass harvard.edu exam
  • »08.11.14 - 03:14
