Trying to Install Wshell install script below
    osco
    Posts: 680 from 2009/10/20
    ; Installs the WShell files on the system disk
    echo "Installing WShell software ..."
    ; Install the commands in C: (or anywhere on a standard path)
    copy clone WShell:c C:
    Manually installed commands in C
    ; Install the library file in LIBS:
    copy clone WShell:libs LIBS:
    Done
    ; Copy the WShell segment (optional for usershell operation)
    copy clone WShell:l/WshellSeg L:
    Done
    ; Copy selected configuration and data files to S:
    copy WShell:s/Config-WShell S: clone
    copy WShell:s/Config-FComp S: clone
    copy WShell:s/CNC-Menus S: clone
    Done I think
    ; Copy the default startup file to S:, unless the user already has one
    if not exists S:WShell-Startup ; already one here?
    copy clone WShell:s/WShell-Startup S:
    endif
    Worried about startup file???? dont want to screw up Ambient shell
    ; Check whether the ENVARC: directory exists (AmigaDOS 2.0 only)
    if exists ENVARC:
    Is there ENVARCC: ??? and where?????
    ; Install default environment variables in ENVARC:
    if not exists ENVARC:titlebar
    copy clone WShell:s/env ENVARC:
    endif
    else
    ; Create an S:ENV directory if necessary ...
    if not exists S:ENV
    echo "Creating S:ENV directory ..."
    makedir S:ENV
    endif
    ; Install default environment variable values in S:ENV
    if not exists S:ENV/titlebar
    copy WShell:s/env S:ENV clone
    endif
    endif
    ; Install selected filter programs
    copy clone WShell:Filters/Tee C:
    filters? where?
    ; Install selected extras
    if not exists sys:rexxc
    copy clone WShell:Extras/WaitForPort C:
    endif
    ; Install the PathHandler files (optional)
    echo "Installing PathHandler Files"
    copy clone WShell:l/PathHandler L:
    copy clone WShell:devs/Path-Mountlist DEVS:
    ; Now clean up obsolete files from the previous release
    if exists C:swaphistory
    echo "Removing old C:swaphistory"
    delete C:swaphistory
    endif
    if exists S:Startup-WShell
    echo "Removing old S:Startup-WShell"
    delete S:Startup-WShell
    endif
    endif
    if exists ENVARC:
    endif
    else
    if not exists S:ENV
    makedir S:ENV
    endif
    endif
    endif
    endif
    endif
    endif
     :-o
    Got tired :-o any responce from the darkness? :-?  :-?
  • »12.08.11 - 17:39
    Posts: 12537 from 2003/5/22
    There's ENVARC: in MorphOS, yes.
    > and where?????
    Open a Shell, type "envarc:" and see where it takes you.
  • »12.08.11 - 18:08
    osco
    Thank-you Andreas one down and three remaining
    Osco :-o
  • »12.08.11 - 19:38
    CISC
    Posts: 619 from 2005/8/27
    What's the problem? Just run the script, everything in it looks ok, the only thing you have to fix is deleting the WaitForPort it copies to C: (MOSSYS:C/ has its own with more advanced options)...
    - CISC
  • »13.08.11 - 06:20
    osco
    Thank-you Andreas and CISC :-D
    Wshell installed  :-)
  • »16.08.11 - 23:56
    osco
    :bloons: :bloons: :bloons: :bloons:
  • »17.08.11 - 00:59
