Posts: 680 from 2009/10/21
How do Mount a pipe?
PIP:GOT THE WSHELL MANUAL
to mount PIP: open up WShell and enter DHOpts CNC: PIP:
Once you've installed the DHOpts command, you can activate the DisplayHandler for
one or more device names using, for example, the command DHOpts CNC: PIP:. The
selected DisplayHandler device names will then appear on the list of AmigaDOS device
names (as shown by the assign devices command, for example.) Note that DHOpts uses
the wshell.library for its operation, so the library must be available at the time the
command is run. Pg.6 WShell manual
MORPH PIPE "IXPIPE"
[ Edited by osco 17.08.2011 - 13:12 ]Mac Mini 1.5GHz, 1G, 250G Drive, Apple Cinema Display, MorphOS 3.1 registered, MacOS 10 PowerBook (5,8) 1.67Hz, 2G, 80G Drive,........Waiting
