Posts: 680 from 2009/10/20
How to format an "agrep" command to search a directory?
ie "Data:text"
all the files end with the extension ".txt" *.txt
finish the command below please
>agrep -l "two;words" * does not work :(
Err I read the manual but?
http://www.gnu.org/software/grep/manual/grep.pdf
The directory have file names that start with a numeric/ does it make a difference?
Buying a concise manual from EBAY....
[ Edited by osco on 2010/6/13 19:28 ]
[ Edited by osco on 2010/6/13 22:33 ]
[ Edited by osco on 2010/6/14 6:23 ]
