rexxdossupport.library/ReadArgs() doesn't work anymore !?
    igracki
    Posts: 463 from 2003/2/24
    anyone noticed that ReadArgs() from rexxdossupport.library doesn't work anymore?
    This test script should output "Name = Thomas", but it show "Name = NAME", which means the var 'Name' isn't initialized.
    Here is the script:
    /* Small ReadArgs() Test of RexxDosSupport.library */
    OPTIONS RESULTS
    CALL ADDLIB("rexxdossupport.library",0,-30, 3)
    template = "Name/A"
    input = "Thomas"
    say "Small ReadArgs() test from rexxdossupport.library"
    say "template: '"template"'"
    say "input : '"input"'"
    say
    say "rc = ReadArgs(input,template)"
    say "rc = "rc
    if rc then
    say "Name = "name
    Tested under v2.4 on Mac mini, rexxdossupport.library is v3.5.
    [ Edited by igracki on 2009/12/28 18:25 ]
  • »28.12.09 - 15:23
