Posts: 451 from 2006/11/16
I am duplicating a small brochure here on my peg2.
I scan the pictures with my amax 2400 scsi scanner and then print them.
I tried graphicspublisher at first to print but it is much smaller in format when printed with this program.
So I use FXpaint to print keeps original format ..almost.
ok for that part but I have to crop all pictures to remove the extra the scanner scanned.
I do this with showgirls but I have to set the same amount each time again with a new picture..not nice.
I did read about the arexx support and did see cropping commands so it may be possible?
But I never used arexx so maybe someone could get me going?
I need to crop 125 off the left and the height should be cropped to 3466.
If I know the syntax I can experiment a bit with this.
