SetWindowPointer
    ShInKurO
    Posts: 36 from 2008/5/30
    hi,
    I've a problem which is probably a sincronization's one with MUI4: I use this code to change pointer image into my subclass into dragbegin method:
    if ((muiRenderInfo(obj))&& _window(obj))
    SetWindowPointer(_window(obj), WA_Pointer, data->dropPointer, TAG_DONE);
    with data->dropPointer a pointerclass object.
    When I dispose object in my dispose method I dispose that dropPointer object and before this I've setted:
    SetWindowPointer(_window(obj), WA_Pointer, NULL, TAG_DONE);
    But 90% ways after to have dispose my object I've freeze system, so is there a new way to change pointer images on MorphOS?
    How could I use MorphOS standard image pointers like OWB does? :)
    [ Edited by ShInKurO 01.07.2012 - 10:00 ]
  • »01.07.12 - 06:58
    Posts: 2578 from 2003/2/24
    Standard pointer:
    SetWindowPointer(_window(display),WA_PointerType,POINTERTYPE_NORMAL,TAG_DONE); (set to normal)
    More types in intuition/pointerclass.h
  • »01.07.12 - 09:30
