MUIA_Window_TopEdge special values
    ncafferkey
    Posts: 38 from 2006/1/6
    Recent MUI_Window autodocs include a new special value for MUIA_Window_TopEdge: MUIV_Window_TopEdge_Bottom. However, its meaning isn't explained. Does anyone here know?
    I also have a query about MUIV_Window_TopEdge_Delta (although not strictly MorphOS related). With MUI 3.8 on 68k, I can't get it to work at all, even though it's in the 68k includes and autodocs.
  • »04.05.17 - 15:23
    r-tea
    Posts: 317 from 2005/3/27
    ncafferkey wrote:
    As I was allways keen on MUI I did a search through internet and the only thing I found is a definition from AROS MUI sources:
    #define MUIV_Window_TopEdge_Bottom(n) (-1000-(n))
    BTW, this keyword isn't recognized while compilin on MorphOS 3.9 with recent MOS SDK.
    Same here on MorphOS 3.9.
    For example,
    MUIV_Window_TopEdge_Delta(30)
    should open the window 30 pixels away from the screen's title bar.
    Compiler (ec) recognizes the keyword and compiles the source, but the program's window appears in the most top of screen and covers the screen's title bar.
  • »04.05.17 - 16:08
    Posts: 3278 from 2003/3/5
    I'm afraid this special value isn't actually implemented - hence the lack of documentation.
  • »04.05.17 - 21:44
    ncafferkey
    Thanks to both of you.
    OK, thanks. Does this go for Delta as well or just Bottom?
  • »06.05.17 - 03:20
    Delta does not seem to be implemented either.
  • »06.05.17 - 21:17
