Howto use mcc files.
    Bastiaan
    Posts: 18 from 2014/8/7
    I'm new to MUI and Amiga development in general. Can anybody give me a pointer on how to use a .mcc file in my GCC based MUI project? I used the show/hide example from MorphOS examples folder as starting point for building my MUI GUI. I want to add the scintilla.mcc class. How do i do this..?
    Thanks,
    Bastiaan
  • »15.04.15 - 17:42
    Posts: 1076 from 2004/9/23
    You simply don´t!
    Just include the related header file.
    If you want to include an MUI object inside your GUI, etc a lamp object, you just
    #include <mui/Lamp_mcc.h>
    And now you can use the macro
    WindowObject, ....
    Child, LampObject, End,
    End;
    Same goes for all external classes.
  • »15.04.15 - 17:47
    Tcheko
    Posts: 540 from 2003/2/25
    You can do this as well if you don't like the macro way
    Object *obj = MUI_NewObject("classname.mcc", MUIA_Foobar, value, ...,TAG_DONE);
  • »15.04.15 - 21:26
    Bastiaan
    Thanks bigtime guys, this amiga programming is just so different then anything ive done before. So far i managed to include the Scintilla header file into my project. The project compiles.. so thats good. But know i'm stuck on creating the actual control in the GUI.
    I have:
    Child, VGroup,
    Child, scintilla = Scintilla(); // <-- something wrong here..
    Child, VSpace(0),
    End,
    End,
    I analyzed the header file, but can't make up the actual name of the control's constructor. Does anybody know if there's any documentation of example online of using the Scintilla.mcc class?
    Thanks.
    [ Edited by Bastiaan 16.04.2015 - 19:25 ]
  • »16.04.15 - 17:22
    pegasos-sigi2
    Posts: 265 from 2006/8/31
    I have:
    Child, VGroup,
    Child, VSpace(0),
    End,
    End,
    Thanks.
    This is the entry to beginning:
    Child, VGroup,
    Child, scintilla = MUI_NewObject("Scintilla.mcc",TAG_DONE),
    Child, VSpace(o),
    End,
    End,
    Every extern MUI-Class must add with above code or with a macro in your custom source.
  • »16.04.15 - 17:52
    Krashan
    Posts: 1107 from 2003/6/11
    While not directly answering your question, reading MUI chapter of this document will give you some background.
  • »17.04.15 - 03:43
    Tcheko
    @Bastiaan : important thing to know. Everything you allocated (memory, port, whatever) shall be *explicitly* released when exiting. There is no resource tracking at all.
    Everything you forgot to release is definitly *lost* (you could remove stuff in system struct afterward, but well, that's a call for disaster).
    Function that returns something and has FreeFunctionName counterpart must work in pair.
    Do not forget to release Lock()ed file either. Upon program exit, the operating system will not unlock the file for you.
    Programming AmigaOS operating system is like dancing on eggs. :)
  • »17.04.15 - 05:20
    Raf_MegaByte
    Posts: 430 from 2004/10/10
    If in doubt how to realize software for MorphOS you can buy this visual development tool:
    Hollywood
    http://www.hollywood-mal.com/
    You realize your software in Hollywood and then with a touch of the mouse, Hollywood will output executable code for all these platforms
    AmigaOS 3 (m68k)
    AmigaOS 4 (ppc)
    Android (arm)
    AROS (i386)
    Linux (arm)
    Linux (i386)
    Linux (ppc)
    Mac OS X (i386)
    Mac OS X (ppc)
    MorphOS (ppc)
    WarpOS (m68k/ppc)
    Windows (i386)
    [ Edited by Raf_MegaByte 17.04.2015 - 09:53 ]
  • »17.04.15 - 06:53
    Bastiaan
    Ok, bring up the cake :D just wrote my first MUI application.. :D
    @Pegasos-sigi2
    Thank you, i finaly got it to work!!! :-)
    @Krashan:
    Thanks and cool, will read into that :-)
    @Tcheko:
    I see! Thank you for sharing this with me, i realy appreciate it!! learning all the time :-)
  • »17.04.15 - 15:16
    Bastiaan
    @Raf_Megabyte: Thanks for the headsup, but i'm not a app generator kind of guy. Doing stuff the hard way haha.
  • »19.04.15 - 16:58
