Some beginners MUI programming questions
    Bastiaan
    Posts: 18 from 2014/8/7
    As i didn't want to flood the forum with multiple threads, i started this thread. Maybe i have some more similar noob question in the future But for now i'm stuck on this:
    I started working on a MUI application in C++ Except i thought i was working in C++, but i found out that in the make file GCC was defined as compiler so i was in C mode. So i switched to G++. After that i got some small compiler warnings which i solved already. But there is one warning which is more difficult:
    main.cpp:144: implicit declaration of function `int set(...)'
    I found this topic on stackoverflow:
    http://www.amiga.org/forums/archive/index.php/t-41334.html
    This guy has the same issue, but didnt come up with the solution. As said in the topic it looks like, MUI's set method conflicts with C++ set method. Does anybody know how to solve this conflict?
    Thanks.
    [ Edited by Bastiaan 18.04.2015 - 20:51 ]
  • »18.04.15 - 18:47
    Bastiaan
    Already got the answer from Geit, will post the solution here for future reference when i got it to work.
    Edit:
    So it worked. The solution was fairly simple..you have to undefine "set" right after loading the mui header file:
    #include <libraries/mui.h>
    #undef set
    Then use SetAttr instead of Set, so for example:
    Set(MUIA_Window_Open,FALSE)
    Becomes:
    SetAttrs(window,MUIA_Window_Open,FALSE,TAG_DONE);
    [ Edited by Bastiaan 18.04.2015 - 21:13 ]
  • »18.04.15 - 18:59
    Posts: 1102 from 2004/9/23
    If you ensure
    __cplusplus
    is defined, than all problems should be gone automatically without any nasty undefines.
  • »18.04.15 - 19:52
