MUI 3.9 vs MUI 4.0
    discreetfx
    Posts: 403 from 2003/7/26
    What are the benefits of using MUI 4.0 for development vs 3.9? We are developing Aladdin 4D 6.0 and use MUI for our GUI toolkit. A4D is for both Amiga OS 4.1 & MorphOS 2.x. We can't use MUI 4 on both OSes since only MorphOS has the latest version.
    DiscreetFX
    Making your
    Digital Films
    More Effective!
  • »13.06.10 - 21:13
    Is MUI4.0 MorphOS native and 3.9 is 680x0? Just a quick guess without doing any research on my own.
  • »13.06.10 - 23:06
    discreetfx
    MUI 3.9 is PPC on Amiga OS 4.1.
    DiscreetFX
    Making your
    Digital Films
    More Effective!
  • »14.06.10 - 00:36
    Posts: 3339 from 2003/3/5
    The main benefit would be the time that has to be spent on the project - with MUI 4 many things that take hours with 3.9 are down to just a DoMethod call - for instance: dynamic tabs can be done with MUI3.9 but require a lot of manual hacking while they're automagic with MUI4.
  • »14.06.10 - 03:02
  • Visitor
  • dynamic tabs can be done with MUI3.9 but require a lot of manual hacking while they're automagic with MUI4.
  • »02.03.15 - 03:13
    Georg
    Posts: 129 from 2004/4/7
    Who came up with this weird implementation/design of dynamic tabs? Stuntzi himself? In OWB sources I saw a triply nested MUIM_Group_InitChange/MUIM_Group_ExitChange while adding new tab ...
  • »02.03.15 - 07:13
    He has indeed. Mind that it's unfinished and the API isn't really public (not part of official SDK).
  • »02.03.15 - 09:10
    Posts: 655 from 2004/4/15
    So back to topic: What are the benefits of Mui 4 besides dynamic tabs (I even donnot know what dynamic
    tabs are, are there static tabs)?
  • »03.03.15 - 03:56
    connor
    Posts: 650 from 2007/7/29
    What is a dynamic tab? A tab that disappears under some condition? Or of variable size? DEpending on what?
  • »03.03.15 - 11:13
  • vox
    vox
    Posts: 616 from 2003/11/24
    There are MUI 4 versions for 68k and OS4 now.
    http://muidev.de/downloads/
    However, differences aren`t well documented or I can`t find much. It seems a lot are visual advancements too :-)
    Hope this show of some MUI4 advancements helps
    http://library.morph.zone/Magic_User_Interface_Programming
  • »03.03.15 - 13:30
    In MUI3, the tabs could only be set at group initialization and one had to re-create the group object to change them (doable, but cumbersome, MUICON did that for example).
    MUI4 is much easier to use when creating interfaces dynamically. It makes it easier to write multithreaded applications as well as adds a lot of new classes.
  • »04.03.15 - 07:32
    Jupp3
    Posts: 1193 from 2003/2/24
    While both 3.9 and 4.0 are based on the same sources, 3.9 is based on much older version, which means 2 things:
    1)It's generally lacking features that 4.0 has
    2)It's trying to replicate newer functionality, sometimes with more, sometimes with less success.
    So 4.0 is "more complete" in general.
    Also, should probably define what "MUI3.9 development" means. It can mean developing for 68k or OS4 (as those are the platforms it's available for, not sure about AROS) or it can mean "general" MUI development for common & properly working functionality available in both, then compiling for "best MUI available" for the current platform (and hope it works). Second is of course a much better choice.
  • »04.03.15 - 18:25
    Posts: 12577 from 2003/5/22
    > not sure about AROS
    MUI 3.9 (and MUI 4.0) for m68k should run on AROS/m68k.
  • »04.03.15 - 22:17
    connor
    so a dynamic tab is a tab that is added or removed after the program has completely started? like a tab in Odyssey? I remember IBrowse could do this, too.
  • »05.03.15 - 10:29
