MUIBuilder
    dekanyz
    Posts: 94 from 2013/2/6
    I have a MUIBuilder question:
    I have successfully created a simple application, but failed to get the sources.
    Could anybody explain me, how goes it exactly?
    The MUIBuilder's user manual isn't too verbose about this.
    BR, dekanyz
    [ Edited by dekanyz 05.04.2013 - 12:17 ]
  • »05.04.13 - 07:16
    tolkien
    Posts: 583 from 2013/5/29
    Sorry but I have exactly the same problem. Any help please?
  • »06.12.13 - 13:04
    Posts: 2577 from 2003/2/24
    MUIBuilder .... *shudders* ....
    MainWindow->Code
    CodeWindow->App Code
    Got NONE.c,NONE.h and NONEMain.c
    [ Edited by Kronos 06.12.2013 - 15:25 ]
  • »06.12.13 - 13:24
    tolkien
    Hi Kronos! Im doing that with my own project and with example ones but nothing happends. Perhaps I have an incomplete install.
  • »06.12.13 - 16:11
    Dunno, those files where created in the MUIBuilder directory.
    And I was useing suffering the 68k-build of MUIBuilder.
  • »06.12.13 - 16:25
    tolkien
    I look for those files in the selected path in options.
    . Ill try the 68k version and see what happends.
    But hey! Whats the problem with muibuilder?
  • »06.12.13 - 16:58
    *I* got no problems with MUIBuilder cos I think it is like all other Amiga GUI-Builders illdesigned and therefore completly unusable.
    I must admit that I'm no big fan of writing my GUIs by hand neither....
  • »06.12.13 - 17:26
    Mazze
    Posts: 20 from 2010/11/6
    There is a problem with the MorphOS port:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=9515&forum=12#104799
    I'm still waiting for someone sending me a fix.
    [ Editiert durch Mazze 06.12.2013 - 21:03 ]
  • »06.12.13 - 19:00
    Mazze
    You can write your own code generator for MUIBuilder but I doubt it will be easy to write one which supports classes.
  • »06.12.13 - 19:03
    @Mazze
    Way ahead of you ...... ;)
  • »06.12.13 - 19:07
    tolkien
    Thanks people. I have replaced muibuilder.library with the 68k version and now all is ok.
  • »06.12.13 - 21:47
    dekanyz
    Hi Guys!
    I try to create a MUI app with MUIBuilder. This app needs a bit more data, what easily could insert into MUIBUilder... So I need some way to handle some MUI objects from some functions.
    Partially I could solve this: Created a Hook what is called, but can't ask the state of a cycle.
    MUIBuilder's generated code is this:
    DoMethod(object->CY_BloodType,
    MUIM_Notify, MUIA_Cycle_Active, MUIV_EveryTime, object->Main_Win,
    2, MUIM_CallHook, &bloodTypeModifiedHook);
    The Hook:
    void bloodTypeModified(struct Hook *hook, Object *object)
    ULONG selectedIndex = 0;
    get(object, MUIA_Cycle_Active, &selectedIndex);
    printf("the selected item is: %un", selectedIndex);
    Could someone help, how to get the selected item?
    [ Edited by dekanyz 24.02.2015 - 09:08 ]
  • »24.02.15 - 06:49
    pegasos-sigi2
    Posts: 265 from 2006/8/31
    DoMethod(object>CY_BloodType,MUIM_Notify,MUIA_Cycle_Active,MUIV_EveryTime,
    object>Main_Win,2,XXX,MUIV_TriggerValue);
    XXX = What attribute or methode do you wish to trigger ??
    if attribute: ...3,MUIM_Set,XXX,MUIV_TriggerValue);
    if methode: ...2,XXX,MUIV_TriggerValue);
    dekanyz wrote:
    Hi Guys!
    The Hook:
    [ Edited by pegasos-sigi2 24.02.2015 - 13:11 ]
  • »24.02.15 - 10:09
    dekanyz
    If I understand you well, my problem is not this.
    The Hook is called... I just dont know, how to get the Cycle's current value in the Hook.
    The 'DoMethod()' isn't my code. It is generated by MUIBuilder... end seems to work well.
    [ Edited by dekanyz 24.02.2015 - 14:09 ]
  • »24.02.15 - 10:43
    pegasos-sigi2
    dekanyz wrote:
    If I understand you well, this is not my problem.
    The consequence of your Notify :
    int selectedIndex;
    get((object>CY_BloodType, MUIA_Cycle_Active, &selectedIndex);
    [ Edited by pegasos-sigi2 24.02.2015 - 15:09 ]
  • »24.02.15 - 12:09
    dekanyz
    I could solve the problem finally. The received object ponter was wrong.
    Thank you for your help!
  • »27.02.15 - 11:50
