Useing MUI as an commodity
    Posts: 2588 from 2003/2/24
    Since all MUI apps also appear as a commodity and my newest little side-project requires both hotkeys, the possibility to insert strings into the input stream and a GUI I tried to go that way.
    From an old demo found on the AOS-DevCD (hotkey.c) and my own MUI-template I glued together this:
    struct Hook brokerHook;
    LONG BrokerHook_Func(void)
    struct Hook *hook = (struct Hook*)REG_A0;
    // struct Data *data = (struct Data*)hook->h_Data;
    PDB(("brokerhookn"));
    return 0;
    struct EmulLibEntry BrokerHookfunc = {
    TRAP_LIB, 0, (void (*)(void))BrokerHook_Func
    #define EVT_HOTKEY 1L
    static ULONG mNew(struct IClass *cl,Object *obj,Msg msg)
    struct Data *data;
    ULONG bport = 0;
    char *hotkey, **ttypes;;
    if (!(obj = (Object *)DoSuperMethodA(cl,obj,msg)))
    return(0);
    GetAttr(MUIA_Application_BrokerPort,obj,&bport);
    GetAttr(MUIA_Application_Broker,obj,(ULONG*)&broker);
    (VOID*)brokerHook.h_Entry = (VOID *)&BrokerHookfunc;
    SetAttrs(obj,MUIA_Application_BrokerHook,&brokerHook,TAG_DONE);
    PDB(("%x %xn",bport,broker));
    if ((filter = CxFilter("rawkey control esc")))
    PDB(("filter %xn",filter));
    AttachCxObj(broker, filter);
    /*if (sender = CxSender(broker, EVT_HOTKEY))
    AttachCxObj(filter, sender);
    return(ULONG)obj;
    As it is the hook is called when I change things in Exchange, but not when I hit "control ESC".
    If I enable the "if (sender..." part hitting that hotkey freezes the system.
    So how do connect "filter" to the broker/msgport of my app ?
    How do I check which hotkey was triggered ( there will be atleast 3 in the finished app) ?
  • »21.06.14 - 10:10
    Replaced with
    if (sender = CxSender(bport, EVT_HOTKEY))
    And it actually worked
    *DOH*
  • »21.06.14 - 12:40
