No Rave3D.library for R300 ?!!?
    serge
    Posts: 725 from 2003/2/20
    Missing Rave3d.library on PowerBook Radeon 9700, and PowerMac G5 Radeon 9600 Pro :-o
    Is this a bug?
    This means no more Warp3D compatibility, so bye bye Amiga Warp3D stuff like demos, games like Heretic II, Shogo, WipeOut 2097 :-o
    Is it a choice bypassing Warp3D Compatibility? A
  • »30.05.13 - 05:46
    SoundSquare
    Posts: 1214 from 2004/12/1
    i noticed that, and Andreas too
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=9&topic_id=8578&post_id=101166&viewmode=flat&sortorder=0&showonepost=1
  • »30.05.13 - 06:02
    SoundSquare
    alright, sorry if i involved you then
  • »30.05.13 - 08:44
    Henes
    Posts: 507 from 2003/6/14
    Since 3.0, tinyl.library is not anymore using rave3d.library.
    Instead, tinygl got its own dedicated driver system allowing much superior performances and features.
    3.0 came with a r200 driver for tinygl.
    3.2 added a r300 driver to tinygl.
    This also means MorphOS runs two 3D driver systems simultaneously, side by side on the very same r200 hardware. Which is technically quite impressive IMHO :-)
    rave3d.library (which always was a private library) and its drivers aren't developed anymore (even though sometimes some bugfix is made, as you can see in the changelogs)
    No r300 driver will be written for rave3d which can be considered as some legacy component.
    It's true warp3d(ppc).library was built around rave3d.library during the previous century and so doesn't benefit from tinygl's r300 driver.
    But this is definitively not a bug. And this is not done for the purpose to break w3d. This is to be considered as a side effect of stepping forward in the 3d area :-p
    So, for now, there is no way to run warp3d crap stuff on r300. It remains to be seen if somebody will one day write some rave3d.library driver using tinygl. Or will modify warp3d(ppc).library to use tinygl.library. Technically both are possible. But today none exists.
  • »30.05.13 - 17:04
    Cego
    Posts: 738 from 2006/5/27
    i would love to play some old PPC Games on MorphOS. Heretic II is still pretty impressive and a really good game. WipeOut is another good game.
  • »30.05.13 - 19:05
    Intuition
    Posts: 1113 from 2013/5/24
    Henes,
    Software rendered 68k Wazp3D.library perhaps?
    http://aminet.net/package/driver/video/Wazp3D
    edit - Nope, just tried running the Cow3D demo from aminet and it doesn't work with the 68k Wazp3D (Nor the OS4 Wazp3D library via OS4Emu), a message box pops up saying "Goa3D graphic - No available Rave 3D driver."
    [ Edited by Intuition 30.05.2013 - 22:50 ]
  • »30.05.13 - 19:13
    SoundSquare
    While i perfectly understand the need to move forward at the cost of loosing some compatibility with older stuff, i still regret it. There is not much 3D stuff available for morphOS appart from games and the morphOS 3D hardware accelerated demoscene is so poor that it is sad to loose most of it (even if these demos were originally coded for PPC amigas). But well, time to move on i guess.
    Anyway, thanks a lot for the clear explanation Henes.
    edit : typos
    [ Edited by SoundSquare 30.05.2013 - 23:50 ]
  • »30.05.13 - 19:38
    Henes
    I need to add that all the systems which could previously run w3d stuff... can still run them with MorphOS 3.0 and up. Nothing was removed and warp3d(ppc).library, rave3d.library etc are still there and work on voodoo3/4/5, radeon r100, r200 as previously...
    Also, again, nothing prevents some w3d -> tinygl bridge to be written in the future. It just has not happened yet.
    @SS
    I still owe you some cake ;-)
  • »30.05.13 - 19:55
    Posts: 12483 from 2003/5/22
    > with the 68k Wazp3D [...], a message box pops up saying "Goa3D
    For installation, the Wazp3D readme instructs to do:
    "Rename existing LIBS:Warp3D.library to LIBS:Warp3D.library-save
    copy Wazp3D.library-full TO LIBS:Warp3D.library
    Did you do exactly that?
  • »30.05.13 - 20:20
    Intuition
    Andreas_Wolf,
    copy Wazp3D.library-full TO LIBS:Warp3D.library"
    I had to rename mossys:libs/Warp3D.library and then it worked.
    It is very slow as I expected though.
    edit - I tried the WipeOut 2097 demo and it fails due to not having a working Warp3DPPC.library.
    [ Edited by Intuition 30.05.2013 - 23:56 ]
  • »30.05.13 - 20:38
    Have you tried duplicating SYS:Libs/Warp3D.library (former Wazp3D.library-full) as SYS:Libs/Warp3DPPC.library and renaming MOSSYS:Libs/Warp3DPPC.library?
  • »30.05.13 - 21:07
    Intuition
    Andreas_Wolf,
    Yes, it complains that Warp3DPPC Library V2 cannot be opened.
  • »30.05.13 - 21:56
    SoundSquare
    @SS
    hehe, let's meet one of these days, it's been a while. I love pudding ;-)
  • »31.05.13 - 05:50
    Posts: 1520 from 2003/2/24
    Unfortunately it doesnt work like that because there are more differences than just a name.
  • »31.05.13 - 06:38
    > than just a name.
    Pity. Would have been too easy, admittedly ;-) So is it correct to assume that you see no way a MorphOS end user can use current Wazp3D to make popular Warp3D programs run with R300?
  • »31.05.13 - 08:09
    It probably wouldnt take much effort create wazp3dppc.library from Wazp3D source code. Bigger problem is probably slow software rendering and poor compatibility with the existing Warp3D software.
    Those could be solved if someone took the ball, though :)
    Edit: it looks like Wzp3D could use TinyGL (?)
    "Hardware OpenGL(Mesa) can be used in AROS"
    http://thellier.free.fr/Wazp3D.htm
    To me it is completely alien stuff...
    [ Edited by itix 31.05.2013 - 13:24 ]
  • »31.05.13 - 08:19
    Intuition
    Andreas_Wolf,
    68k Warp3D programs work with Wazp3D software rendering on R300 (But extremely slowly) but WarpOS PPC programs don't.
    I could have a go at modifying Wazp3D to use TinyGL.library but its all foreign to me so I probably wouldn't get very far without a great deal of time and help.
    I might have a look to see how complicated it would be on Saturday night.
  • »31.05.13 - 13:47
    Cego
    i'd love to see a r300 support of rave3d with the next release :)
  • »31.05.13 - 16:46
    Another possible solution might have been proposed there:
    http://amigaworld.net/modules/newbb/viewtopic.php?topic_id=37710&forum=46&start=100#708065
    This driver requires original Warp3D to be installed.
  • »02.06.13 - 12:42
    serge
    Andreas_Wolf,
    I tryed this solution but it doesn't work realy. Shogo, Heretic II and WipeOut 2097 doesn't work.
    Only things I could started were MenoBox and ImuBox.
    [ Edited by serge 02.06.2013 - 23:51 ]
  • »02.06.13 - 19:50
    Both points confirmed by the Wazp3D author:
    http://amigaworld.net/modules/newbb/viewtopic.php?topic_id=37710&forum=46&start=100#708159
  • »03.06.13 - 08:21
    boot_wb
    Posts: 874 from 2007/4/9
    Update from Alain Thellier:
    BTW if a Morphos coder wants to recompile Wazp3D with OpenGL support for Morphos and encounters some problems he may contact* me : I will help him for wazp3D & GL side
    but for the OS specific part (ie Morphos lib-header & creating a custom GL context) I wont help him as I dont know Morphos' OS-dependant-coding at all :-/
    Alain Thellier - Wazp3D author
    * my mail is in the wazp3d readme
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »19.06.13 - 10:08
    BSzili
    Posts: 570 from 2012/6/8
    I'm interested in doing this, although I'm currently busy with RTTR. I'll contact Alain Thellier.
  • »19.06.13 - 11:41
    I'll admit, this was a disappointment I was not prepared for (after buying and converting several R300 cards for MorphOS use).
    In fact, I've downgraded back to Radeon 9000Pro cards.
    But if we could do this re-compilation, we wouldn't have to worry about similar problems with other video cards we might want to adopt in the future.
    Current, the G5 PowerMac that we've just adopted could potentially handle R400 cards (so X800XTs are a possibility with a new driver).
    And, PCIe G5s are ever supported, then R500 cards like the X1900GT are a possibility.
    So...hopefully some ambitious individual will step up.
    Just don't expect Frank or Mark to want to tackle it. They've both accomplished enough recently that they deserve nothing more than our kudos.
    Which, btw, they definately have on my part.
    Way to go guys. I'm really enjoying playing around with the iBook (I'll get around to a G5 eventually - probably after 3.3 is released). :-D
    [ Edited by Jim 20.06.2013 - 00:36 ]
  • »19.06.13 - 21:34
