TinyGL: FBO, Shaders and futur improvements
    ernsteiswuerfel
    Posts: 570 from 2015/6/17
    man schrieb:
    it s only for x5000 the graphic card radeon hd5450 ?
    i like to know if it s possible to use with powermac g5
    About 2 years ago a tried a PCIe HD5450 in my PowerMac G5 11,2 (the later, PCIe-model) which worked perfectly fine with the MorphOS drivers at that time (though without 3D-Support back then).
    Another HD6450 didn't work at all on MorphOS (but did on Linux). So as bigfoot said it's a bit of hit and miss on a G5.
    If I had an AGP G5 (7,2 or 7,3) I would not be brave enough to use one of these AGP->PCIe adapters. Tried that on my PeeCee back then but had lockups and seemingly random freezes on Windows/Linux. But if someone actually is brave enough to try I would be interested how good/bad the performance of such an adapter solution is. ;-)
  • »09.07.23 - 08:29
  • man
    man
    Posts: 136 from 2019/11/11
    here the video on youtube
    https://www.youtube.com/watch?v=WPDd1Y0flSg
    don t know if with morphos and the hd graphic card
    if the hd5450 model pcie pc works with powermac g5 i like to know if there s no problem with 3D and it would be very a good news
  • »10.07.23 - 04:05
    eastone
    Posts: 47 from 2007/8/4
    Me and my MDD with RV620 AGP are waiting for 3D.
    HD3850 would be better, but if you don't have what you like, you like what you have ;)
    MDD with Radeon HD AGP
  • »10.07.23 - 14:01
  • man
    man
    OK
  • »10.07.23 - 15:50
  • MDW
    MDW
    Posts: 488 from 2003/7/25
    bigfoot wrote:
    Morphiller demo now also runs on the Radeon HD 5450, except the final report screen that seems to misrender a bit.
    It's an honor for me that you checked my little production. I am very happy. :-)
    Regarding final report screen maybe in my implementation is a reason of the problem. End scroller, launcher and the report screen uses my quite complicated GUI-system. Maybe I will be able to help for detect reason of the problem?
    [ Edited by MDW 11.07.2023 - 18:55 ]
  • »11.07.23 - 14:55
    bigfoot
    Posts: 510 from 2003/4/11
    You released it while I was working on the R600 driver. Of course I had to test it :D Thanks for the shout-out in the scroller, BTW ;)
    If you have any suggestions as to what might be causing the misrendering, I'd be happy to hear! Here's a screenshot of the problem. The end scroller and the settings GUI both seem to render correctly as far as I can tell, it's really only this results screen that's giving a problem.
    I also just noticed that if I enable the FPS counter, the FPS counter misrenders the same way the report screen does.
  • »12.07.23 - 06:19
  • MDW
    MDW
    Yes, FPS counter uses the same GUI-view and font.
    Characters in each string (also wrapped) are created as one vertex array with proper coords, texcoords and (in case of a font with gradient) vertex colors. The vertex array is kept in string view and is recreated only if this is necessary (e.g.: the view is resized, the string is modified, color of the text is changed). Font uses texture in grayscale as alpha for flat (or gradient) faces:
    glEnable(GL_BLEND);
    glBlendFunc(GL_SRC_ALPHA, GL_ONE_MINUS_SRC_ALPHA);
    This allows you to easily change the color of fonts because I use this:
    glTexEnvi(GL_TEXTURE_ENV, GL_TEXTURE_ENV_MODE, GL_MODULATE);
    Problem visible on your screenshot can concerns the texture. I use mipmapping… Maybe in case of grayscale textures there is a problem with generating mipmaps?
    glGenTextures(1, &textureGLName);
    glBindTexture(GL_TEXTURE_2D, textureGLName);
    glPixelStorei(GL_PACK_ALIGNMENT, 1);
    gluBuild2DMipmaps(GL_TEXTURE_2D, GL_ALPHA, width, height, GL_ALPHA, GL_UNSIGNED_BYTE, data);
    glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MIN_FILTER, GL_LINEAR_MIPMAP_NEAREST);
    glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MAG_FILTER, GL_LINEAR);
    However… I don't think so because I use grayscale textures in GL_LUMINANCE and GL_ALPHA format very often on 3D objects and we see that everything looks correctly.
    Only differece between rendering font mesh and object mesh is:
    before rendering a font I use this:
    glOrtho(0, viewport.getWidth(), 0, viewport.getHeight(), -1, 1);
    before rendering a 3D mesh I use this:
    gluPerspective(fovY, aspect, nearZ, farZ);
    The report is rendered with disabled depth buffer testing
    glDisable(GL_DEPTH_TEST);
    disabled polygon culling:
    glDisable(GL_CULL_FACE);
    and with alpha blending:
    glEnable(GL_BLEND);
    But these functions:
    glDepthMask();
    glDepthFunc();
    are not used in case rendering of only 2D layer. On end scroller and in launcher before rendering 2D layer is rendered a 3D scene.
    I will look for potential reason of the problem. Maybe I will detect more differences between rendering 3D+2D and only 2D...
    [ Edited by MDW 12.07.2023 - 14:38 ]
  • »12.07.23 - 10:04
    bigfoot
    Although there are still plenty of known issues with the R600 driver, I've decided to the ninth public TinyGL beta release with a preview of the R600 driver included.
    Although this is called the R600 driver, in this update only Evergreen and Northern Islands based Radeons are supported. Support for R600 and R700 based Radeons will be added at a later date.
    Since the R600 driver is a preview driver with known issues, expect to find plenty of applications and games that either misrender or crash the system. If you come across something that doesn't work correctly, please report it here in this thread and in the case of misrendering, please include a screenshot as well.
    Edit: The newly supported Radeons are the following models:
    Radeon HD 5450
    Radeon HD 5550
    Radeon HD 5570
    Radeon HD 5610
    Radeon HD 5670
    Radeon HD 5750
    Radeon HD 5770
    Radeon HD 5830
    Radeon HD 5850
    Radeon HD 5870
    Radeon HD 5970
    Radeon HD 6350
    Radeon HD 6450
    Radeon HD 6570
    Radeon HD 6670
    Radeon HD 6750
    Radeon HD 6770
    Radeon HD 6790
    Radeon HD 6850
    Radeon HD 6870
    Radeon HD 7350
    Radeon HD 7450
    Radeon HD 7470
    Radeon HD 7510
    Radeon HD 7570
    Radeon HD 7670
    Radeon HD 8350
    Radeon HD 8450
    Radeon HD 8470
    Radeon HD 8490
    Radeon R5 220
    Radeon R5 230
    Radeon R5 235
    Radeon R5 235X
  • »14.08.23 - 09:02
    Posts: 911 from 2004/1/24
    Edit: The newly supported Radeons are everything in the Radeon HD 5000 series, everything in the Radeon HD 6000 series as well as Radeon HD 7350, Radeon HD 7450, Radeon HD 7470, Radeon HD 7510, Radeon HD 7570, Radeon HD 7670, Radeon HD 8350, Radeon HD 8450, Radeon HD 8470, Radeon HD 8490, Radeon R5 220, Radeon R5 230, Radeon R5 235 and Radeon R5 235X
    Sweet!!! :pint:
  • »14.08.23 - 12:48
    Posts: 12441 from 2003/5/22
    > The newly supported Radeons are […] everything in the Radeon HD 6000 series […]
    Nice. Does this include improved 2D support for TeraScale 3 (RV970-based HD 69xx)?
  • »14.08.23 - 16:07
    bigfoot
    No, you're right. It still very much excludes Cayman-based Radeons. I'll update the list in the post you quoted.
  • »15.08.23 - 05:32
  • MDW
    MDW
    Hey @bigfoot
    Have you received my e-mail (July, 18th 2023, subject "depth buffer in tiinygl")?
    I still can't found reason of the simple problem in rendering with enabled depth buffer test but disabled writing to depth buffer. I don't see any reason why the artifacts are visible. Polygons on the same z-position shouldn't collide if writting to depth buffer is disabled. I used this method quite often and it always worked without any problems (also on macOS).
    I attached to the mail simple source which shows the the problem. It is reporducible on my PowerBook G4 A1138.
    I use TinyGL from MorphOS 3.18. I haven't tried the ninth public TinyGL beta release yet.
    [ Edited by MDW 15.08.2023 - 12:11 ]
  • »15.08.23 - 07:55
    bigfoot
    MDW wrote:
    Hey @bigfoot
    Yes I have! I'm a bit behind on replying to emails, sorry about that. I'll get to yours in the near future.
    That won't make a difference, so you don't have to test.
  • »16.08.23 - 10:08
  • MDW
    MDW
    No problem. I can imagine your TODO list. :)
    I asked you because I had some problems with my account @amiga.pl so I didn't know if my e-mail was received. Now I know so I don't hurry up please. It is not a blocker for me, I don't have any deadline. I have thousand other tasks in my lame-project. :)
    Thanks!
  • »16.08.23 - 12:24
    matt3
    Posts: 760 from 2004/2/10
    Checking in on any updates?
    If it would help I'm happy to pitch in to get a G5 PCIe system to Bigfoot.
  • »11.11.23 - 17:27
    Posts: 2502 from 2003/2/24
    You might wanna add a generator to that .....
  • »11.11.23 - 18:24
    Posts: 1932 from 2003/10/19
    I would as well! I would do anything to get support for the newer cards like OS4.1 has on its systems.
  • »11.11.23 - 21:40
    Posts: 1081 from 2003/3/24
    Yeah +1
  • »18.11.23 - 22:26
    tolkien
    Posts: 555 from 2013/5/29
    Hi friends!
    Any news about this?
    Just for curiosity..not pressure! :)
  • »05.06.24 - 18:57
    matt3
    The offer still stands by me and other to buy and ship a PCIe based PowerMac to Bigfoot.
  • »06.06.24 - 11:24
    Posts: 50 from 2018/6/9
    Question...
    Radeon HD 8490 is one of the cards listed as added in the newest TinyGL beta. I have no clue what these cards are like in terms of performance, 2D / 3D overlay, etc. but there seem to be a lot of OEM Dell and HP cards on eBay for like £15. Anyone got any idea if these would work? I'm looking for something to try in the 4x slot of my X5000 (via an extender due to physical limitations).
    Assuming we don't know, and I give it a go, is the release 9 of the TinyGL driver included in the download of MOS 3.18 so the card will work from boot or are there complications in bringing up a fresh system with such a card?
  • »30.06.24 - 20:44
    These drivers are not needed for booting, so anything that is listed for 2D in the 3.18 FAQ will work.
  • »01.07.24 - 01:15
    So, the reason I asked the question is because the card in question (HD8490) is listed in this thread (previous page), but isn't listed at all on the Morph 3.18 hardware FAQ page. I don't think it really matters TBH. When I looked up the hardware it seems that an 8490 isn't really much better than the HD5450 that I do have. Unfortunately that one refuses to work in the 2nd slot.
  • »01.07.24 - 17:04
    https://www.morphos-team.net/hardware
    AMD Radeon HD3830, HD3850, HD3870
    AMD Radeon HD4350, HD4550, HD4570
    AMD Radeon HD4670
    AMD Radeon HD4750, HD4770
    AMD Radeon HD4810, HD4830, HD4850, HD4870
    AMD Radeon HD4860, HD4890
    ATI Rage128 Pro
    With 2D graphics acceleration, no overlay:
    AMD Radeon HD5450, HD6350, HD7350, HD8350, R5 210
    AMD Radeon HD5550, HD5570, HD5610, HD5670, FirePro 3D V3800, FirePro 3D V4800
    AMD Radeon HD5750, HD5770, HD6750, HD6770
    AMD Radeon HD5830, HD5850, HD5870, HD5870 Eyefinity Edition
    AMD Radeon HD6450, HD7450, HD7470, HD8450, HD8470, HD8490, R5 220, R5 230, R5 235, R5 235X
    AMD Radeon HD6570, HD6670, HD7510, HD7570, HD7670
    AMD Radeon HD6790, HD6850, HD6870
    So it is listed and it should give you a basic working system on a clean 3.18 install.
    But sure it was an entry level card released 11 years ago, so I wouldn't ecpect much.
  • »01.07.24 - 17:42
    Sorry, don't know how I missed that. I did look, honest!
  • »01.07.24 - 19:58
