3D RAVE
    ShadowIRIS
    Posts: 1 from 2004/3/13
    Hi
    I wanne do some 3D RAVE programming for MOS, but where do I find the
    includes and link libs? I have the MorphsOS SDK, but I cannot find any
    thing in relation to 3D RAVE
  • »13.03.04 - 11:44
  • Zapek
    Posts: 5 from 2003/2/28
    http://vgr.com/v4/rave3d.html
    David Gerber
  • »13.03.04 - 14:24
    hooligan
    Posts: 1948 from 2003/2/23
    Yo Shadow.. there's also #pegasos @ ircnet these days.. welcome!
  • »13.03.04 - 15:25
    Estrayk
    Posts: 142 from 2003/12/30
    Welcome to the MOS boat Shadow.
    We hope see some demos from you soon!
    :D
    Config: PegasosII G4/1000, 256MB DDR400, VooDoo 3000 AGP
  • »17.03.04 - 08:27
    Posts: 48 from 2003/5/13
    shadow : You should use OpenGL for 3D stuff. But there is no more SDK available for this API.
    Zapek : I can't understand how you could advice to use Rave3D because :
    - OpenGL is the official API for MorphOS
    - the web page is old, all things on are outdated : dead links, no docs, stuff for old CGFX, ... better to use Warp3D
    The page is so clean that I can't find a developer archive easily. Are you laughing at us ? You have to know we don't have time to waste ...
  • »17.03.04 - 17:03
  • Zapek
    The guy asked for rave3d so I gave him rave3d links. Now shut up and go back skiing.
    David Gerber
  • »17.03.04 - 18:04
    rebamarvin
    Posts: 1 from 2014/1/29
    I am running 2.4 on a MacMini. I have enabled "Enhanced display" in the 24bit 1680x1050 screenmode i am running.
    I am trying to run tokais Elephant to see the "3d layers" in all its glory but when I run it I get an error saying "3D layers engine required for transparent look. Falling back to opaque mode". And then a rather boring elephant appear.
    Do I have to do anything more than enable "Enhanced display"?!?
    Materials including latest free braindumps and ISC exam. good luck
  • »29.01.14 - 05:00
    analogkid
    Posts: 722 from 2004/11/3
    Do you have a 1,5GHz Mac mini with 64MB VRAM? I think the "Enhanced Layers" option needs at least 64MB VRAM.
  • »29.01.14 - 05:12
    Posts: 1390 from 2010/1/6
    You may also use enhanched display with 32MBVRAM, but 1680x1050x24 is too big. Try to use 16Bit instead and/or a lower resolution.
    1280x1024x16 works fine here......
  • »29.01.14 - 06:34
    Posts: 12569 from 2003/5/22
    In case this isn't a typo, you should really upgrade to 3.4 before doing anything else.
  • »29.01.14 - 06:50
