MorphOS on A1200
    Murray
    Posts: 10 from 2009/8/24
    Yes I'm trying to get Morph 1.4.5 running on my A1200PPC also. Why? To do things the hard way I suppose, and I hate quitting. I can't get the system to boot from the CD or from a bootable partition on the scsi harddrive. I have tried reading through previous posts - perhaps I've missed something. Why does the system ask for the ENV volume? Does it make in difference that my CD player is on the BlizzPPC scsi device? Thanks.
  • »01.09.10 - 02:13
  • JJ
    JJ
    Posts: 147 from 2010/7/7
    I might be mistaken but from memory does it only support booting off the internal IDE ?
    And does not support the extra channels on powerflyer.?
    We don't stop playing because we grow old; we grow old because we stop playing. - George Bernard Shaw
    Xbox Live: S0ulA55a551n2
  • »01.09.10 - 07:48
    amiades
    Posts: 231 from 2005/6/2
    I think that was for OS4... MorphOS supported blizzppc.device IIRC...
  • »01.09.10 - 11:18
    vulture
    Posts: 196 from 2008/2/4
    I run MOS from a sfs scsi partition just fine. Just make sure the mos boot partition is within the 1st 4gb of the disk.
  • »01.09.10 - 14:58
