MorphOS PowerUP (Deneb)
    Posts: 236 from 2003/7/28
    I am trying to get MorphOS PowerUP to work on my A4000/CS PPC/CV PPC with Deneb. I have flashed the Deneb with the necessary files as per the instructions in Luciferin.
    However, I believe the "startup" command arguments need to be changed. Does anyone know what they should be? If I try startup it complains it can't find the hal...
    not sure what to do...
  • »24.01.10 - 04:30
