OWB 1.1 on MOS (PowerUp)
    VooDoo
    Posts: 189 from 2005/8/24
    What I need for running last OWB on my MOS classic ?? I try to run it but nothing :)
    Last 4-5 months my mOS is not activ and dont know what update,or what files I need for runnin this great sw ??
    If anyone here using OWB on classic MOS please help me!
    Thanx!
    A1200 sandwich
    uA1c/g3 800 mHz/256mb/160gb hdd/OS4.1  :-D
    Warp croatian Amiga portal :
  • »27.03.09 - 06:41
    Tcheko
    Posts: 543 from 2003/2/25
    Hello,
    You should try to see what's missing with snoopdos.
    Czk
  • »27.03.09 - 06:48
    Posts: 1521 from 2003/2/24
    Do you have Update Pack 1?
  • »27.03.09 - 07:19
    VooDoo
    Yes I have it!!Quote:
    A1200 sandwich
  • »27.03.09 - 09:21
    VooDoo
    Now I try run SnoopDos and OWB..but all is OK..no missing files...
    Maybe memory is problem ?? now I have only 96MB fast on ppc card ???
    A1200 sandwich
  • »27.03.09 - 10:33
    Daff
    Posts: 251 from 2003/4/5
    How many RAM do you have before launchin OWB ? (at least 64 ?)
    http://obligement.free.fr
  • »27.03.09 - 11:22
    Sir_Lucas
    Posts: 112 from 2006/4/23
    Which version are u trying to run?
    Try the lite version.
    http://fabportnawak.free.fr/owb/
  • »27.03.09 - 11:24
    VooDoo
    Wohooo.....lite version is working on my MOS....is littl slow..but is OK...
    And loading OWB istoo long...tt fonts is killin my CPU  ;-)  :-(
    A1200 sandwich
  • »27.03.09 - 14:44
    SoundSquare
    Posts: 1214 from 2004/12/1
    it's only painful the first time : )
  • »27.03.09 - 23:30
    VooDoo
    Yeah,now I run it in 5-8 sec...and that is great for 233mhz and old 603 ;)
    A1200 sandwich
  • »28.03.09 - 06:17
    Sir_Lucas
    That's great. I'm glad that it works fine now.
  • »30.03.09 - 18:34
