Trance - SetTaskPri :-)
    SKOLMAN_MWS
    Posts: 107 from 2006/10/24
    ; MOSSYS:S/Startup-Sequence
    Run <>NIL: DETACH QUIET Trance
    TaskPri Trance 0 >NIL:
    TaskPri Trance 127 >NIL:
    :roll:
    LoadWB
    EndCLI
    8-)
    http://img296.imageshack.us/img296/9451/taskmenageryh7.png
    more information go to page ->
    http://www.ppa.pl/forum_ppa/read.php?f=4&i=5948&t=5702#reply_5899
    _
  • »04.11.06 - 00:54
    AmigaMancer
    Posts: 265 from 2005/8/25
    Hello Skolman and welcome.
    I know what the command does, but i don't understand what the benefits are, and most ppl here don't speak polish. Care to explain? :-)
    Amiga 1200 user.
  • »04.11.06 - 03:35
    Posts: 109 from 2006/9/10
    Does this speed up 68k emulation on MOS Powerup systems? Could you elaborate a bit further?
    I will do some benchmarking anyway.
  • »04.11.06 - 10:37
    I can tell you one thing for sure: it will NOT speed up the banana. ;)
    ...since MisterBananas is PPC/MOS-native and does not use Trance?  ;-)
    No idea if it's placebo or not - at least there is a 2-pages thread on that Polish-site, so there must be something about it.
    I hope the original poster get's back to this thread.
    [ Edited by quadpol on 2006/11/4 17:50 ]
  • »04.11.06 - 14:49
    magnetic
    Posts: 2129 from 2003/3/1
    Yes I'd like to know what these means as well as I dont read Polish either.
    magnetic
  • »04.11.06 - 20:44
    SKOLMAN_MWS
    OK, speed up IBrowse, Visage and other 68k progz. MiamiDX not crash and more :-D
    Lame68k test enc audio 30 sec to mp3. BPPC 210MHz
    MOS (Priorytet Trance -99 ) - time 29 min 49 sec
    MOS (Priorytet Trance 0 ) - time 3 min 25 sec (!)
    http://www.ppa.pl/forum_ppa/read.php?f=4&i=4709&t=4709
    _
  • »05.11.06 - 01:02
    VooDoo
    Posts: 189 from 2005/8/24
    Where can download this cool progy :) :) for speedUp my MOS apps
    A1200 sandwich
    uA1c/g3 800 mHz/256mb/160gb hdd/OS4.1  :-D
    Warp croatian Amiga portal :
  • »05.11.06 - 09:12
    Piru
    Posts: 608 from 2003/2/24
    This can be considered the official MorphOS Team response
    - Hacking Trance priority is not recommended. The perceived advantages come with a price: Anything else running at low priority will be blocked.
    - The only advantage to get from these priority games comes from the fact that JIT translation is not delayed. However, this results in easily visible system jerkyness.
    - Trance priority is low for a reason: JIT translation is complex operation and Trance can potentially keep the CPU 100% busy for a long time. To make sure the JIT operation doesn't bog down the whole system, low priority was chosen.
    - If you choose to play tricks with the priority, you're doing this at your own risk.
  • »05.11.06 - 10:29
    Framiga
    Posts: 363 from 2003/7/11
    Hi Piru
    "- Trance priority is low for a reason: JIT translation is complex operation and Trance can potentially keep the CPU 100% busy for a long time. To make sure the JIT operation doesn't bog down the whole system, low priority was chosen."
    this is exacly what i thought when i read this thread. (although what many thinks, i have a great respect and consideration for the MOS Team.... as programmers)
    Anyway (only because i'm "curious like a monkey") i've tryed myself.
    Whats the results? no clue honest! (apart that i can change Trance pri only through Scout)
  • »05.11.06 - 11:30
    SKOLMAN_MWS
    TaskPri download with Aminet  8-)
    _
  • »07.11.06 - 19:37
    AmigaMancer
    Edit: Dangerous "tip" removed by me. Sorry.
    [ Edited by AmigaMancer on 2008/11/12 21:28 ]
    Amiga 1200 user.
  • »12.11.08 - 09:40
