Posts: 732 from 2003/2/24
have you tried with reset level 7? The lower values are for BlizzardPPC...
Are you using real rom or fake rom? If you use a real rom save it using uae's transrom and don't use downloaded roms that may be from A500/A1200/A2000... if you don't use fakerom you'll need real rom.
You could also use skolman's modules if you want paula sound and floppy disk and don't want to use real rom (all in all that's the only useful thing from the real rom)...
http://skolman-mws.w.interia.pl/mos/extmodules.lhaunpack the archives and copy trackdisk.device and audio.device to boot/extmodules
and remember to change startup-sequence to:
set kickstart "nokickstart"
Have you disabled MapRom in the CSPPC scsi menu that appears pressing ESC?
BTW, if you use ROMulus/Algor you may need updated luciferin modules for the flashrom to make it boot.
[ Edited by Crumb on 2008/5/7 9:04 ]
