The Age old getting MOS to strat on a BPPC
    Buleste
    Posts: 3 from 2008/2/6
    I have a A1200 with BPPC 200mhz 040 25mhz with ZorroIV with CV64/3d, a 4 way buffered IDE with 20gb HDD and CDROM. I'm trying to install MOS and have read many posts on how to get it working but to no avail. I've tried using a FFS partition and am using a SFS 1.84 partition at the moment. I normally have 256Mb of RAM but have reduced it to 128mb i've tried idehack, with rom and without rom with colon and without but i still only get so far which is the startup works and resets but i then just get the black screen. I've not been able to boot from CD either. i can't connect to a PC as i don't have the cables. Can anyone help?? this is my current startup-sequence..
    ; This is the MorphOS loader startup-sequence. If you set the MorphOS partition as bootable,
    ; this file would cause MorphOS to get loaded on boot automaticly.
    ; By default MorphOS boots without using the ROM contents of your Amiga. If you wish to
    ; make it use the kickstart contents (to be able to use trackdisk.device for example)
    ; please follow those steps:
    ; 1) Check if you have a correct kickstart file:
    ; The Kickstart version required are:
    ; Amiga4000/4000T/3000 - 40.68 or 40.70
    ; Amiga1200 - 40.68
    ; Is is advised that you use the unpatched ROM files
    ; 2) Move or delete fakerom.elf from boot/extmoudles
    ; 3) Change the kickstart variable, remember to tune the file path
    set kickstart "kickstart=DH1:Devs/ROM3.1"
    ;set kickstart "nokickstart"
    ; Bootdevice can be used to specify the MorphOS partition if you have more than one
    ; bootable partition and the MorphOS one doesn't have the highest boot priority. Remember
    ; to use partition names, not volume names! This option requires the 'bootdevice' keyword
    ; like in the example below:
    set bootdevice "bootdevice=DH1:"
    ; Leave the var blank if you want to boot from the default boot partition!
    ;set bootdevice ""
    ; The resetlevel and delay variables are there for you to tweak if MorphOS startup doesn't
    ; reboot the machine properly after loading MorphOS files.
    ; The possible resetlevel values are:
    ; 0 exec/coldreboot (System Reboot)
    ; 1 MMU switch off + normal reset in chipram (default)
    ; 2 MMU switch off + double reset in chipram
    ; 3 MMU switch off + Cyberstorm HW Reset in chipram
    ; 4 for (;;);..waiting for manual reset by your hands:-)
    ; 5 MMU switch off + normal reset in fastram
    ; 6 MMU switch off + double reset in fastram
    ; 7 MMU switch off + Cyberstorm HW Reset in fastram
    ; NOTE: most common setting for BlizzardPPC is resetlevel 1 and 5 for CyberStormPPC!
    set resetlevel 1
    set delay 1
    ; Load the MorphOS loader!
    cd DH1:boot
    startup hal=roms/hal.com1 kernel=roms/kernel.com1 abox=roms/abox2.com1 module=roms/module.com1.idehack resetlevel=$resetlevel ramdebug verbose debug EDebugFlags="NoLogServer NoLogWindow" sumkick disableled delay=$delay extmodules=extmodules/#? $bootdevice $kickstart
  • »06.02.08 - 12:39
    Framiga
    Posts: 363 from 2003/7/11
    is your HD in the 4 way buffered IDE first channel?
    How big is the MOS partition?
    Have you deleted the fakerom.elf file from Boot/extmodules/ ?
    then change theese linnes with the default one:
    set kickstart "kickstart=Devs:ROM3.1"
    cd sys:boot
    and try someone that could send you a previous Boot/module.com1
  • »06.02.08 - 13:22
    Buleste
    The HDD is on the first channel i.e scsi unit 0.
    The MOS partition is 2GB
    Fakerom has been deleted.
    I've tried the default lines and module.com1
  • »06.02.08 - 13:26
    sunmax
    Hi there!
    >> CV64/3d
    Amazing... MorphOS is the first telepathic OS! I was planning to
    report the same issue yesterday. I browsed the forums just to
    make sure nobody already discussed that and worked out a solution
    and -puff!- it magically appeared...
    ...so here come my 2 cents:
    I have (actually had for a while ;-) MorhpOS running on a BPPC
    240/050 with SCSI. I have both a Phase5 [rev. 0] and a DCE BPPC
    and -contrary to some urban legends- both works fine with
    MorphOS Powerup on my GRex + Voodoo3. It's stable and works
    both from the SCSI HD (on the BPPC) and from the IDE HD frome
    the Amiga mobo. I run it on both a 1D.4 and a 2B and it's pleasant
    and stable on both.
    Now, since AmigaOS4 is out and there is no grex support I wanted
    to have a setup that let me use both OS4 and MorhpOS so I run this
    experiment:
    I took one of my MorphOS boxes and replaced the G-REX +
    Voodoo3 with a Micronik Zorro II busboard + CV64/3D. OS 3.9
    and 4.0 worked flawlessly on that setup (well OS 3.9 already was
    before ;-), but when I tried to run MorphOS I had a cold shower...
    ...MorphOS does not start anymore (yeah, black screen, you guess
    it). Keep in mind that MorphOS worked perfectly before, the only 2
    variables changed were : grex -> micronik Z2 busboard , voodoo3
    -> CV64/3D
    I even tried with another Zorro II busboard (the ZorroIV that our
    MorphOS friend Buleste is using) and I had the same experience:
    *** the CVision3D.Z2 68K module locks with an "Exception 3"
    [Store to a not existing Page] during PPC_ColdBoot_603e ***
    If you replace it with the .Z3 module you can see that CVision3D.Z2
    is the faulty part cause the initilization will go one step forward, you
    will see a flash on the screen, and then (I am debugging from
    serial) you will read:
    Hello, Ambient here. I couldn't open a screen so I'm trying to
    communicate through the serial port. Hopefully someone can see
    this.
    Please check the following:
    - working and supported graphics card
    - latest version of the boot.img kernel
    - booting from the correct device
    - driver installed in mossys:devs/monitors
    Which is expected cause it fails to initialize the Zorro III bus, but
    the module at least does not generate an "Exception 3" loop.
    Note, that as soon as I replaced Grex + Voodoo3 back, Morphos was
    very happy to boot again ;-)
    My hunch is that something was messed up in hal.com1, when they
    fixed the Zorro III initialization to get CV64/3D work on Zorro III
    Amigas, but broke the Zorro II version... IIRC the Zorro III version
    had a similar issue with a failure in correctly mapping memory
    pages.
    If somebody has an older (or newer) version of hal.com1 that has
    the correct support for CV64/3D or a version of CVision3D.Z2 that is
    supposed to work with MorphOS 1.4.5 I will be more than glad to
    try it.
    Attached is 1 loop (cause it will keep printing the same series of
    messages over and over) of serial debug where you can see what
    CVision3D.Z2 is messing up.
    I hope some MorphOS guru out there can help us!
    Thanks.
    Best Regards,
    -max lingua
    ASM_Exception: DAR 0x5c0010 DSISR 0x42000000
    ASM_Exception: IntGPR1 0x88004fc0 SRR0 0x11017be4 SRR1 0xf070 LR 0x1100708c
    ASM_Exception: Type 0x3
    ASM_Exception: Thread 0x880a4a20 Name ABox
    Quark Thread:
    TID 0000000010020010
    Name ABox
    Exception 3 <Illegal Data Access at 005c0010 DSISR 42000000, Store to a not existing Page>
    SRR0 0x11017be4 SRR1 0x0000f070
    LR 0x1100708c CTR 0x11017bcc
    CR 0x08002048 XER 0x00000000
    GPR[00] 00000010 682275d0 68227650 000109a0 68000000 10804fe4 00000084 00000080
    GPR[08] 6b4fe000 00000000 00000002 00000100 28002044 6822d8d8 00000004 11328724
    GPR[16] 00200000 005e8000 00000001 000007ff 00000001 00000000 ffffffff 00000000
    GPR[24] 005c0000 005c0000 005c0000 68000c44 681cea88 68217ff8 68000c44 681f1928
    FPSCR 43efff0000104010
    FPR[00] 0000000010020010 0000000000000000 0000000000000000 0000000000000000
    FPR[04] 0000000000000000 0000000000000000 0000000000000000 0000000000000000
    FPR[08] 0000000000000000 0000000000000000 0000000000000000 41f0000000000000
    FPR[12] 4330000000000000 0000000000000000 0000000000000000 0000000000000000
    FPR[16] 0000000000000000 0000000000000000 0000000000000000 0000000000000000
    FPR[20] 0000000000000000 0000000000000000 0000000000000000 0000000000000000
    FPR[24] 0000000000000000 0000000000000000 0000000000000000 0000000000000000
    FPR[28] 0000000000000000 0000000000000000 0000000000000000 0000000000000000
    IABR 00000000
    DABR 00000000
    MMCR0 00000000
    MMCR1 00000000
    MMCR2 00000000
    PMC1 00000000 PMC2 00000000 PMC3 00000000 PMC4 00000000
    SIA 00000000
    SDA 00000000
    PPCStackFrame History:
    StackFrame[-0].LR-> Address 0x110087ec -> Emulation Hunk 0 Offset 0x000087ec
    StackFrame[-1].LR-> Address 0x1010d840 -> Module Hunk 0 Offset 0x0000d840
    StackFrame[-2].LR-> Address 0x1010da6c -> Module Hunk 0 Offset 0x0000da6c
    StackFrame[-3].LR-> Address 0x11007df4 -> Emulation Hunk 0 Offset 0x00007df4
    StackFrame[-4].LR-> Address 0x1129efa0 -> Emulation Hunk 0 Offset 0x0029efa0
    StackFrame[-5].LR-> Address 0x1100708c -> Emulation Hunk 0 Offset 0x0000708c
    StackFrame[-6].LR-> Address 0x110087ec -> Emulation Hunk 0 Offset 0x000087ec
    StackFrame[-7].LR-> Address 0x102d34dc -> Module Hunk 0 Offset 0x001d34dc
    StackFrame[-8].LR-> Address 0x102d31dc -> Module Hunk 0 Offset 0x001d31dc
    StackFrame[-9].LR-> Address 0x102ab32c -> Module Hunk 0 Offset 0x001ab32c
    StackFrame[-10].LR-> Address 0x102a78f4 -> Module Hunk 0 Offset 0x001a78f4
    ABox State
    Hardware:
    Intenar 0x602c Intreqr 0x0041 Int 0x3f
    ExecBase: SysBase 0x68000c44
    SysFlags 0x0000c000 AttnResched 0x00000000 IDNestCnt -1 TDNestCnt 0
    ThisTask 0x681f9f40 TaskReady 0x680397d8 TaskWait 0x680453e0
    ResModules 0x68002f60
    TaskTrapCode 0x1010098c TaskExceptCode 0x1010067c TaskExitCode 0x101006d8
    TaskSigAlloc 0xffff TaskTrapAlloc 0x8000
    IdleCount 1195
    DispCount 9007
    Quantum 4
    Elapsed 3
    VBlankFrequency 50 PowerSupplyFrequency 50 EClockFrequency 709379
    MainTID 0x10020010
    SchedulerTID 0x10020021
    SchedulerSig 0x80000000
    OldSRR0 0x0
    ConfigServerTID 0x10000013
    Int0: iv_Code 0x00000000 iv_Data 0x00000000 iv_Node 0x00000000
    Int1: iv_Code 0x1014950c iv_Data 0x6800ec10 iv_Node 0x6800ec5e
    Int2: iv_Code 0x101006ec iv_Data 0x00000000 iv_Node 0x00000000
    Int3: iv_Code 0x10100568 iv_Data 0x68002c18 iv_Node 0x00000000
    Interrupt 0x6800df22 <ciaa.resource>
    Code 0x101488e4 Data 0x6800def8
    Interrupt 0x6806b6d0 <blizzppc.device>
    Code 0x6806b6c8 Data 0x6806b6bc
    Interrupt 0x6805f4dc <ide4000.driver>
    Code 0x6805f4f4 Data 0x6805f408
    Int4: iv_Code 0x10100568 iv_Data 0x68002c38 iv_Node 0x00000000
    Int5: iv_Code 0x10100568 iv_Data 0x68002c28 iv_Node 0x00000000
    Interrupt 0x6800fb7e <graphics.library>
    Code 0x10150518 Data 0x6800fb34
    Interrupt 0x68025228 <gameport.device>
    Code 0x68025220 Data 0x68025160
    Interrupt 0x6815e3c4 <PPC 50Hz Timer>
    Code 0x6815e3bc Data 0x6815e2b0
    Interrupt 0x681a8a30 <bonusppc int>
    Code 0x681a8a28 Data 0x681a8a28
    Int6: iv_Code 0x10150520 iv_Data 0x6800fb34 iv_Node 0x6800fbaa
    Int7: iv_Code 0x00000000 iv_Data 0x00000000 iv_Node 0x00000000
    Int8: iv_Code 0x00000000 iv_Data 0x00000000 iv_Node 0x00000000
    Int9: iv_Code 0x00000000 iv_Data 0x00000000 iv_Node 0x00000000
    Int10: iv_Code 0x00000000 iv_Data 0x00000000 iv_Node 0x00000000
    Int11: iv_Code 0x00000000 iv_Data 0x00000000 iv_Node 0x00000000
    Int12: iv_Code 0x10149514 iv_Data 0x6800ec10 iv_Node 0x6800ec74
    Int13: iv_Code 0x10100568 iv_Data 0x68002c48 iv_Node 0x00000000
    Int14: iv_Code 0x00000000 iv_Data 0x00000000 iv_Node 0x00000000
    Int15: iv_Code 0x10100568 iv_Data 0x68002c58 iv_Node 0x00000000
    Running Task
    Task 0x681f9f40 Name 0x681fe024 <Background CLI> Type 13 Pri 0
    Flags 0x8 State 2 IDNestCnt -1 TDNestCnt -1
    SigAlloc 0x0000ffff SigWait 0x00000100 SigRecvd 0x00000100 SigExcept 0x00000000
    ExceptCode 0x1010067c ExceptData 0x00000000 TrapCode 0x1010098c TrapData 0x00000000
    Switch 0x00000000 Launch 0x00000000 UserData 0x00000000
    SPLower 0x681ed9f0 SPUpper 0x681f19f0 SPReg 0x681f1900
    ETask 0x681ce834
    MemPool 0x681c9920 PPCLibData 0x00000000
    PPCSPLower 0x6821fee4 PPCSPUpper 0x68227ee0
    PPCTrapMsgPort 0x00000000 PPCTrapMessage 0x681c9bc4
    PPCRegFrame 0x68227030
    Private[] 0x00000000 0x00000000 0x00000000 0x00000000
    EmulHandle 0x00000000
    EmulHandle 0x68227650 Type 0x00000004 Flags 0x00000000
    SuperHandle 0x10001000 Type 0x00000000 WaitMask 0x00000000 SyncMask 0x00000000
    USP 0x00000000 SSP 0x68002888 VBR 0x6800d090
    SFC 0x00000000 DFC 0x00000000 CACR 0x00000000 TC 0x00000000
    ITT0 0x00000000 ITT1 0x00000000 DTT0 0x00000000 DTT1 0x00000000
    URP 0x00000000 SRP 0x00000000 BUSCR 0x00000000 PCR 0x04310000
    SRR0 -> Emulation Hunk 0 Offset 0x00017be4
    LR -> Emulation Hunk 0 Offset 0x0000708c
    CTR -> Emulation Hunk 0 Offset 0x00017bcc
    Emul PPC mode: Current 68k context
    PC 6822d8d8 SR 0004
    Dn[0] 00200000 005e8000 00000001 000007ff 00000001 00000000 ffffffff 00000000
    An[0] 005c0000 005c0000 005c0000 68000c44 681cea88 68217ff8 68000c44 681f1928
    PC -> CVision3D.Z2 Hunk 0 Offset 0x000059e8
    Stack: 0x681f1928
    A7[-32] 00000000 00000000 00000000 00000000
    A7[-16] 00000000 00000000 00000000 6822d8d0
    A7[000] 00000001 000007ff 00000001 00000000
    A7[016] ffffffff 00000000 00000000 68000c44
    A7[032] 681cea88 68217ff8 68217ff8 681cea88
    A7[048] 005c0000 11328720 68228ed8 00001000
    A7[064] 681cdad4 00000001 fffffffe 00000000
    A7[080] 00000000 68217ff8 00000000 00000000
    A7[096] 102af350 68000c44 00000001 00000000
    A7[112] 00000000 681c9b81 681c9ac4 00000000
    A7[128] 681c9ba3 00000000 681c9b91 00000000
    A7[144] 681c9c9c 6815f164 00000100 00000000
    A7[160] 681c9c50 6821814c 68002d74 11328720
    A7[176] 68227ff4 68030558 00000000 11328720
    A7[192] 00004000 681fe020 00001e28 681c993c
    A7[208] 681c9938 0a000000 00000000 681f1a98
    A7[224] 681f1a18 681f3818 00001d80 49484452
    A7[240] 681f1a58 00000000 00000000 00000000
    0x681cea88 -> CVision3D.Z2 Hunk 1 Offset 0x00000000
    0x11328720 -> Emulation Hunk 0 Offset 0x00328720
    0x68228ed8 -> CVision3D.Z2 Hunk 0 Offset 0x00000fe8
    0x102af350 -> Module Hunk 0 Offset 0x001af350
    0x68227ff4 -> CVision3D.Z2 Hunk 0 Offset 0x00000104
    Last saved PPCThread State:
    SRR0 0x1011e6b4 SRR1 0xf070 LR 0x1010fb48 R1 0x68227410
    GPR[00] 102bb988 68227410 68227650 00000010 68078c50 1010fb88 00000001 00000000
    GPR[08] 00000000 68082b5c ffffff38 68000c44 0000f070 6815efe8 00000000 11328724
    GPR[16] 6815f164 00000008 00000001 000007ff 00000001 00000000 681f9f40 00000000
    GPR[24] ffffffff fffffffe 00000000 1a07277f 68007b18 68227478 68227418 68000c44
    SRR0 -> Module Hunk 0 Offset 0x0001e6b4
    LR -> Module Hunk 0 Offset 0x0000fb48
    CTR -> Module Hunk 0 Offset 0x0000fb88
    SegList 0x1a0726c0 GlobVec 0x68078d60
    StackBase 0x1a07b67c StackSize 0x00004000
    TaskNum 0x00000003 Result2 0x00000000
    CurrentDir 0x1a0726c7 CIS 0x1a0209a5
    COS 0x1a020a85 CES 0x00000000
    ConsoleTask 0x00000000 FileSystemTask 0x68007b74
    CLI 0x1a020b31 ReturnAddr 0x681f19e8
    PktWait 0x00000000 WindowPtr 0x00000000
    HomeDir 0x1a0726d3 Flags 0x00000024
    ExitCode 0x00000000 ExitData 0x00000000
    Arguments 0x681cdad4 ShellPrivate 0x00000000
    CmdName: <CVision3D.Z2>
  • »07.02.08 - 23:08
    Framiga
    i'm not an CV3D user but AFAIK you have to rename the driver as
    CVision3D (along its icon)
    yep ... just received your mail! :-)
    confirmed!
    88784 Jan 3 08:19 CVision3D.Z2
    87776 Jan 3 08:20 CVision3D.Z3
    5940 Aug 10 2005 CVision3D.info
    as you can see the info have the correct filename hence your using a driver with a name and its info with another
    [ Edited by Framiga on 2008/2/11 17:43 ]
  • »11.02.08 - 16:34
    Crumb
    Posts: 736 from 2003/2/24
    @sunmax
    your problem is that some of the defined screenmodes can't be shown with the CV3D.
    I had a similar problem when I downgraded from PicassoIV to CV64, as the gfx chip is not capable of showing all screenmodes. You could try to connect your g-rex again, choose 640x480@60hz as ambient screenmode save, and connect your CV3D again.
  • »12.02.08 - 10:24
    Buleste
    Thanks for the suggestions but still having no joy. Any other ideas?
  • »12.02.08 - 13:38
    sunmax
    Thanks for your hint.
    >> to CV64
    Was it causing a: Exception 3 - Store to a not existing Page ?
    Shouldn't MorphOS fail in a more graceful way and just
    say: mode not supported? ;-)
    Which is actually what happens if you try to replace
    CVision3D with CVision3D.Z3 (instead of Z2) on A1200
    + Zorro2 busboard:
    "Hello, Ambient here. I couldn't open a screen..."
    I am going to definitely try your suggestion, it could
    take a while cause to reopen a Micronik tower and
    safely remove all the precious Amiga parts twice
    (grex in, grex out once again) it's not an easy task!
    In the meanwhile, is there a way I could hexedit the
    ambient prefs? Or could somebody just send me
    a safe config file with sensible screen mode for CV3D
    for me to test before the week-end? Thanks a lot!
    Is there a way to force a mode from "startup" ?
    btw: should I chaneg something in the CVision3D.info too?
    the one that comes with MorphOS 1.4.5 PowerUP has :
    BITMAPCACHE=YES
    PACKED24=NO
    BOOTLOGO=YES
    SCROLLMASK=NO
    Is thak OK?
    @Buleste
    Did you try Crumb suggestion too?
    How do people that just have a Zorro2 + CV3D setup
    (and no g-rex, etc.) setup sort it out? Thanks!
    Ciao,
    -max
  • »12.02.08 - 21:09
    AmigaMancer
    Posts: 265 from 2005/8/25
    After the first reset, does the hard disk start to load things for some seconds or you just get a black screen with no HD activity?
    [ Edited by AmigaMancer on 2008/2/13 2:39 ]
    Amiga 1200 user.
  • »13.02.08 - 00:38
    Framiga
    but ... are you really saying thats ok having in MOSSYS:Devs/Monitors/ such a
    CVision3D.Z2
    CVision3D.info
    just for curiosity?
  • »13.02.08 - 17:06
    sunmax
    Hi there!
    @Framiga
    Ciao!
    >> such a
    >> CVision3D.Z2
    >> CVision3D.info
    Yep,
    at least for me MorphOS is picking the correct one depending on
    the Zorro bus detected. You can see that this is the case cause
    if you rename "CVision3D.Z2" to "CVision3D" you get the same
    identical Exception 3 error, but for the drv name cause it's now
    trying to load "CVision3D". The priority is
    1 - "CVision3D" (if available)
    2 - "CVision3D.Z2" or "CVision3D.Z3" (depending on the bus)
    Because of this you can fool MorphOS to try to use the Z3 one
    on a Z2 box by renaming CVision3D.Z3 to CVision3D, not
    very useful but at least you get Ambient "talking" to you ;-)
    See my serial debug.
    @AmigaMancer
    It does spin the HD and load some data after the first reset,
    this is proved by:
    a) I can hear it [not very useful unless you are next to me]
    b) The Exception (did you see my serial debug) happens
    -after- PPC_ColdBoot_603e which is succesful,
    cause what fails is running CVision3D.Z2 and
    logically this could not happen if the system did
    not load it and try to execute it after the reboot, no?
    I hope somebody can provide me with a CVision3D
    friendly Ambient config/prefs file (see Crumb hint),
    cause it's a huge task to open and rebuild the Micronik
    tower twice just to create that file. Thanks!
    Anybody out there?
    Thanks,
    -max
  • »13.02.08 - 20:59
