Where i can get MOS PUP 1.4.5 rev3?
    BalrogSoft
    Posts: 171 from 2006/10/6
    Hi, i have an A1200 with a BPPC and BVision, but i never got it working, it tried different reset levels, fakerom and real rom, different sfs versions, but i found on this forum that last MOS PUP iso have problems on some configurations, and someone suggested MOS 1.4.5 rev3, where i can download MOS 1.4.5 rev3?
    Balrog Software - AmigaSkool.net
    Mac Mini - MorphOS 3.8 - G4 1.5Ghz - Ati 9200 64 Mb
    Efika - MorphOS 3.6 - Ati 9200 64Mb - 80 Gb HD
    Amiga 1200D - OS 3.9 - Blizzard 603e/240mh
  • »21.04.07 - 21:57
    Framiga
    Posts: 363 from 2003/7/11
    use the "SYS:Boot/roms/module.com1.idehack" renaming it as:
  • »21.04.07 - 22:04
    BalrogSoft
    Hi, i tried idehack module before, and i tried to rename it also, and it don't work, i get a black screen and nothing happens...
  • »22.04.07 - 10:57
    Framiga
    you have not to "try" it only... you have to USE it.
    If this doesn't works the problem is elsewhere.
  • »22.04.07 - 12:19
    BalrogSoft
    Indeed i "used" it, and don't work, here is the post where i found the information about rev3:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=4769&forum=42
    Someone have rev3 of newest MorphOS version?
  • »23.04.07 - 17:16
    Crumb
    Posts: 732 from 2003/2/24
    change:
    set bootdevice "DH0"
    by
    set bootdevice "bootdevice=DH0"
    use idehack version instead of the default one.
    Use the fakerom instead of the real ROM.
    I have got it running on my A3000 today and it rocks! :-D
  • »24.04.07 - 23:28
    BalrogSoft
    Hi Crumb, i made those changes even before publish any message here, bootdevice, idehack, fakerom, boot priority, and nothing works ... :-?
  • »26.04.07 - 11:41
    CLS2086
    Posts: 168 from 2005/8/25
    Hum... FFS ? PFS ? SFS ?
    Keep the Faith !
    VG 5000/A1000/500/500+/600/2000/1200PPC-GREX/1200PPC-ATEO/1200+1230-IVFPUSCSI/CD32/Pegasos 1 April1 G3/Pegasos 2 G4/ Ahtlon/K6-3/various funny machines too :-)
  • »26.04.07 - 18:13
    Crumb
    which hardware do you have connected?
  • »26.04.07 - 22:57
    Sir_Lucas
    Posts: 112 from 2006/4/23
    Don't mess so much ;)
    Just use the default settings as the Crumb says.
    Use FFS, you can reformat your hard disk later.
    I don't even use the fake rom.
    The simpler the settings are the better chances you have to launch the Mos PUP ;)
    Change the name of hackmodule to module.com1
    I've managed to run Mos Pup on my A1200 and A4000T on standard scsi controler as I've been waiting for the terminator for the UW Scsi disks ;)
    Btw, who told you about rev3, never heard about such a name? Can you provide the link plz?
  • »27.04.07 - 07:27
    BalrogSoft
    I don't remember the version of installed sfs, i will check it, i bought a SCSI - IDE adapter, i hope that it will work better than IDEfix, i will make more tests with ffs and the new adapter, thanks a lot...
  • »30.04.07 - 19:02
