Posts: 641 from 2004/1/25
i have made already two pc psus working with amiga... it's simple, you just need a multimeter, solder and some small intelligence
Measure all of the pins that supplies your amiga of the amiga psu, you should get some gnd, +12, -12, +5 and -5 Volts (i hope so... just don't remember exactly), then cut the Amiga cable near to the psu, release all those wires, and mark, which one brings to amiga what...
then open the pc psu, and find where are all those needed poweroutputs, and solder there your wires from the amiga cable... that's all... now you have a strong pc psu with amiga cable, and that should be enough... for every amiga configuration
bye, MarK.
ps: i could do it for you, if you would send it to me
[ Edited by MarK on 2007/4/13 6:26 ]
