fdd/paula drv for extmodules without rom kickstart
    SKOLMAN_MWS
    Posts: 107 from 2006/10/24
    set kickstart "nokickstart"
    http://skolman-mws.w.interia.pl/mos/extmodules.lha
    _
  • »26.03.07 - 22:11
    Sir_Lucas
    Posts: 112 from 2006/4/23
    Nice one!!!
    Now that we have paula we can try to run Napalm under Mos PUP.
    Have you tried running Napalm under MOS if not, give it a try and share your experiences with others ;)
  • »28.03.07 - 11:16
    AmigaMancer
    Posts: 265 from 2005/8/25
    @SKOLMAN_MWS
    Your MOS tips are appreciated. Thank you. :-)
    Ed: trackdisk.device goes to boot/extmodules or i have to create a boot/extmod-off directory and put it in there?
    [ Edited by AmigaMancer on 2007/3/28 13:46 ]
    Amiga 1200 user.
  • »28.03.07 - 11:41
    SKOLMAN_MWS
    @Sir_Lucas
    yes Napalm act/running on MorphOS :-)
    www.aminet.net/game/demo/napalm_1.1.lha
    @AmigaMancer
    "extmod-off" - there is only example disable modules.
    _
  • »28.03.07 - 21:24
    Sir_Lucas
    Ok. Let me put it this way.
    Due to the great Skolman today I've been able to run NAPALM under Mos PUP.
    It roxxx!!! The speed is incredible comparing to 68k.
    Playability is also great!!!!
    Skolman thx again!!!!
  • »29.03.07 - 19:39
    magnetic
    Posts: 2129 from 2003/3/1
    Hi guys
    This sounds interesting. Can you please elaborate on what this is please?
    magnetic
  • »30.03.07 - 00:00
    AmigaMancer
    @magnetic
    It's about the extraction of audio.device and trackdisk.device from a 3.1 ROM and their usage as external modules. This way, there is no need to use a 512k ROM image just to enable the disk drives and direct audio.
    PS: I wish there was a MOS native audio.device. It would reduce frame skipping in movie players etc.
    Amiga 1200 user.
  • »30.03.07 - 04:43
    Sir_Lucas
    Ok. Here are the steps how to run Napalm Demo, I didn't have enough time to check if the full version works, but:
    Before you start reading, please bear in mind that it's not my idea, this all came from Skolman ;)
    1. extract this file and copy it to the boot directory
    2. Download the demo version of Napalm from the Aminet
    3. Extract it
    Copy rtgmaster.library rtgCGX.library and Suzy with subdirectories as it is to SYS:Libs; then start the game from the icon; next rtgscreenmode 8bit 640x480
    4. It should start from the first time
    5. Have fun ;)
    Say thank you to Skolman ;)
    That's all
    Please write your impessions here ;)
    [ Edited by Sir_Lucas on 2007/3/30 21:27 ]
  • »30.03.07 - 21:25
