Well... you won`t overclock your precious Amiga Hardware.. you really won`t do that ;) (You may try to run snoopdos during startup and have a look in the logfile, afair it is possible to have all tooltypes which a prog provides, listed.) But again... you won`t overclock that ;)
I have already overclock my BVision without any problems under AmigaOS. Of course, i cool the card sufficiently. Running snoopdos is a good idea. I'll try it. Thanks :)
