Which A1200 fast IDE interfaces are supported byMOS?
    AmigaMancer
    Posts: 265 from 2005/8/25
    I notice in the last 2 MOS-PUP updates that an experimental support for these adapters is added.
    Which adapters are supported though? I'm thinking of buying an IDEFix express, mainly because it's cheaper than FastATA and because i don't have any high requirements like those that FastATA offers. But if it's not supported by MOS, i'll have to re-think about it.
    [ Edited by AmigaMancer on 2007/1/7 20:57 ]
    Amiga 1200 user.
  • »07.01.07 - 18:55
    VooDoo
    Posts: 189 from 2005/8/24
    ..Only standard IDE controller is suporrted..Here I using FastATA whit MOS..but without speed work only in 4-IDE adapter mode :)...That is what I need...FastATA driver..only that :(
    A1200 sandwich
    uA1c/g3 800 mHz/256mb/160gb hdd/OS4.1 :-D
    Warp croatian Amiga portal :
  • »07.01.07 - 21:04
    AmigaMancer
    I see. I had the impression that there was some support for these boards, although somehow experimental. It seems that i was wrong..
    So, basically, both IDEFix express and FastATA acts as a simple IDE buffer/4-way splitter in MOS.
    [ Edited by AmigaMancer on 2007/1/8 1:48 ]
    Amiga 1200 user.
  • »07.01.07 - 23:34
    Otti
    Posts: 20 from 2004/3/31
    @VooDoo
    How did you get MOS to work with the FastATA?
    I only could start MOS if i unplug the HD on the secondary port.
    And which resetlevel are you using?
  • »20.01.07 - 17:23
    Framiga
    Posts: 363 from 2003/7/11
    on my A4000 with a passive 4Way-adapter, the 2nd channel isn't recognized.
  • »20.01.07 - 19:49
    SKOLMAN_MWS
    Posts: 107 from 2006/10/24
    @Otti
    resetlevel no problem. problem is nativ cdfilesystem
    cdromboot scsi.device and other in kernel morphosrom.
    MorphOS 0.4 compatible 100% with FastATA.
    _
  • »25.02.07 - 20:00
