Problem with create Morphos Key for PowerUP Card
    Falcon_11
    Posts: 35 from 2004/2/7
    Hi all
    had anyone yet this problem by registration
    This answear is from ChainQ
    "Thank you for trying to register PowerUP MorphOS, but it seems
    your PowerUP card in your Amiga has damaged and broken flash
    data, so it's impossible to create a valid MorphOS key for
    your card.
    Unfortunately, reflashing won't help, since the flash updates
    doesn't touch the necessary flash area."
    My configuration
    Amiga1200, PC-Tower,
    Blizzard PPC 603/210-040/25,
    BVision, 64 MB FastRAM,
    3COM PCMCIA Network Adapter
    FastATA 1200 (FULL 32bit),
    MorphOS PUP, AmigaOS 3.9
    Is possible fixed this problem.
    Sorry for my bad English.
    Falcon_11
    [ Edited by Falcon_11 on 2007/1/8 1:16 ]
    DEAD
    Pegasos-II
    Powerbook G4 A1139, MOS3.19
  • »07.01.07 - 22:12
    Framiga
    Posts: 363 from 2003/7/11
    i never stop to learn something new!
    Do you have that PowerUP card up&running with MOS? (i guess yes since you have tryed to register)
    Do you have the ENABLE56KHZ command in "MOSSYS:C" loaded from "MOSSYS:S/Startup-Sequence" (just after IPrefs)?
    [ Edited by Framiga on 2007/1/8 15:17 ]
  • »08.01.07 - 12:15
    Posts: 1521 from 2003/2/24
    It is not possible to generate MorphOS key for your BPPC because some parts of flash are damaged and it can not be fixed.
  • »08.01.07 - 12:18
    Falcon_11
    Thanx Itix.
    I don t know what is wrong, becouse it works normal, My card has got any problems with MorphOS.
    Do you know, what is wrong in Flash Area, how could it damage, and how can i repair it? Phase5 is out, DCE ????, Already, i have this card 9 years.
    DEAD
    Pegasos-II
  • »14.01.07 - 08:53
  • Leo
    Leo
    Posts: 419 from 2003/8/18
    Any chance you can register Falcon_11 by hand ?
    Leo.
  • »14.01.07 - 09:16
    tokai
    Posts: 1289 from 2003/2/25
    No, it's simply not possible (not manually nor automatically.. which is technically the same thing actually). We sadly can *not* create any working keys for such cards.
    regards,
    Christian Rosentreter
    (MorphOS support team)
  • »14.01.07 - 11:08
    Posts: 3296 from 2003/3/5
    BlizzardPPC's flash gets damaged when you abort the flashing process. Even if you manage to reflash the card after this and it works OK, the flash area is already corrupt. This makes it impossible for us to create a key. It's as simple as that.
    As far as I know, there's nobody who could help you fixing the card.
  • »14.01.07 - 11:22
    Falcon_11
    Thanx for answears boys. Now i m dreep  :-( when nobody can`t fix this problem. I have made flashing on my card 6 times, latest Flash wos before X-mass and i have never seen on my Screen abort or someting similarly.
    One question yet. When i have this problem, will least AmigaOS work normal ? When no, this card have`t for me any price.
    DEAD
    Pegasos-II
  • »14.01.07 - 14:26
    tokai
    AmigaOS will work fine, even MorphOS would so (if there wasn't the key thing).
    I guess that approx 5% of all cards have this problem. Maybe its related to a particual flash update which does an improper update and trashes the flash rom. Very hard to tell.. and there are not too many living cards out there to validate and test that anyway.
    Best is to get a cheap Pegasos2 from somethere. Or an EFIKA as soon MorphOS is out for it (should be noticable faster than MorphOS on a PowerUP system, I think).
    regards,
    tokai
  • »15.01.07 - 02:20
    dIGIMAN
    Posts: 273 from 2005/11/7
    Maybe.
    Maybe its worth trying to downgrade to an old version, and try to register again.
    Or a certain old version and then a new one.
    I have the Problem with the MK3, i could use fastrom with a certain option.
    When i lost the kickstart in fastmemory, i had to downgrade the cyberstorm mk3, run fastrom, and then upgrade again :)
    Well..
  • »15.01.07 - 08:39
    logain
    Posts: 21 from 2003/4/15
    @Falcon_11
    Got the same problem here
    @tokai
    Looking at his signature reveals that he already owns a Pegasos 2. I own a Pegasos (1) too and theres no doubt that i'll get an Efika.
    Yet running MorphOS on the Blizzards or Cyberstorms is something special, for obvious reasons.
  • »15.01.07 - 20:36
