The what would seem famous black screen of death
    Posts: 3 from 2006/8/16
    Hi All - Helo Needed please
    I downloads the iso from the correct place. Burnt using nero. Copied the files across to a blank partition. None of the protection bits were sety on either the cd or the files copied across.
    Anyway solved this by using protect #? +RWED ALL on the files
    Now when I boot (the partition is bootable and is not the first booting partition) using the eraly startup just get a black screen on both the amiga output and the bvision output.
    I have changed the reset levels, but anything apart from 1 gives my a please insert env requester.
    I have not changed the startup-sequence apart from the rest levels, so I am using the fake kickstart.
    The machine has 3.1 roms, should i be booting with a 3.1 kickstart file.
    My config is
    A1200 rev 1A mobo. 3.1 roms.
    Blizzard 040/25 & 603e 175 no scsi, Bvision attached - from memory blizzard flashed with latest firmaware - maprom set to off
    64MB ram
    Z4 Busboard , nothing connected to zorro slots
    Eytech keyboard adapter
    2 gig IDE HDD attached to first channel of powerflyer gold/fast ata , 52x cdrom attached to second channel
    Everyhting is fine under AOS3.1 and 3.9
    Thanks in advance for any tips , help :)
  • »16.08.06 - 12:56
    it has been suggested that the lastest version of the iso has issues with my setup and i need the version berfore. Where would obtain this from please
  • »16.08.06 - 18:54
    Posts: 23 from 2006/6/22
    Hey dude,
    Here's what you need:
    right-click and save as
    Replace the module.com1 file in boot/roms with this one; it's from the previous version.
    That should get you a bit further, as I was in the same situation. :-)
    HTH! :-D
  • »16.08.06 - 21:26
    cheers for that, will give it a whirl and let u know
  • »16.08.06 - 21:57
