Setmemmode command for MOS?
    AmigaMancer
    Posts: 265 from 2005/8/25
    Hi.
    I want to be able to control the ram access speed on-the-fly in MOS, just like in AOS with the setmemmode command.
    The problem is that this command doesn`t seem to work in MOS. It reports "No 680x0 >= V43 available.". The snoopdos reports "setmemmode OpenLib 68040.library Ver 43 Fail".
    Any suggestions?
    Amiga 1200 user.
  • »17.07.06 - 13:27
    Framiga
    Posts: 363 from 2003/7/11
    i've tryed exactly the same "experiment" few days ago with the same result.
    Btw AmigaMancer... can you test this thing?
    if you set in the PowerUP Boot Menu a value for Transfer Offset (i.e 10) and then you check through UnitControl, do you have the same value?
    Under AmigaOS yes while under MOS, is always set to 15.
  • »17.07.06 - 16:22
    AmigaMancer
    I don't see a transfer offset setting. It's probably a SCSI or PCI setting, thus i can't give you feedback about it.
    [ Edited by AmigaMancer on 2006/7/18 2:29 ]
    Amiga 1200 user.
  • »18.07.06 - 00:27
    Framiga
    ah you don't have SCSI ok thanks anyway.
    Anybody else?
  • »18.07.06 - 15:00
    Framiga
    bump
  • »16.08.06 - 13:04
