Repulse Sound card
    DJBase
    Posts: 745 from 2003/4/6
    Is anyone using a Repulse sound card with MOS? I couldn't get a single sound out of the speakers. The card seems to be recognized and everything is installed and configured. Works under AmigaOS but not under MOS PUP.
  • »15.07.06 - 22:49
    Framiga
    Posts: 363 from 2003/7/11
    RepulseGold working here (with "some" timing/initialization problems but its working)
    If you have installed all properly and you don't have any sound, try to rise in AHI prefs, the Volume to 1.0 db and do an Avail Flush before to start the player.
    Run >NIL: repulseinit QUIET (in UserSS)
    repulse.library in SYS:Libs/
    AHI-Audiomodes (repulse.audio etc) in MOSSYS:Devs/
    [ Edited by Framiga on 2006/7/16 13:57 ]
  • »16.07.06 - 10:51
    DJBase
    Ok, now thats working (except sometimes timing problems).
  • »16.07.06 - 11:36
    Framiga
    EDITED- long story
    [ Edited by Framiga on 2006/7/17 11:50 ]
  • »16.07.06 - 12:16
    CISC
    Posts: 619 from 2005/8/27
    probably due the "bugged" MOS 1.4.5 timer device
    You mean the NSA is listening in on your timer requests, or what? ;)
    - CISC
  • »16.07.06 - 14:46
    Posts: 1932 from 2003/10/19
    Hey Framiga its not good practice to put things in the mossys: other then official things from the team. You can use the standard sys: instead and it will survive any version update you install when they come out.
  • »16.07.06 - 15:55
    Framiga
    CISC
    if i had the freaking idea of what a NSA is, i would answer ;-)
    i know
  • »16.07.06 - 16:27
    Posts: 2564 from 2003/2/24
    You may not know what the NSA is, but the NSA for sure knows who you are :boo: :boo:
  • »16.07.06 - 17:33
    Framiga
    uh! can i sleep safely tonight? :angel:
  • »16.07.06 - 17:42
    CISC
    replaced "b###ed" with "not perfectly working" :-D
    I still don't understand what you're trying to say though .. there are no known bugs in timer.device that could possibly affect this driver, if you know something we don't please share it.
    - CISC
  • »17.07.06 - 02:34
    Framiga
    ok! sharing time....
    I have some weird issue related to the playing speed with AHI and RepulseGold. (that have 68K driver(library)
    Add to this that i've heard on your IRC (#morphos)that the timer.device have a problem, so i thought that the timer.device was the problem.
    Am i wrong? so apologize then.
  • »17.07.06 - 08:49
    CISC
    Yes, there is a bug related to timer.device usage, however this is almost certainly not your issue (as the effect of it if this would be triggered is entirely different).
    So either this is a bug in the driver, RepulseGold, AHI or somewhere else in MorphOS, please find out which. ;)
    - CISC
  • »18.07.06 - 02:59
