A3000 w Mediator BB
    amipeg
    Posts: 2 from 2006/7/2
    does anyone managed to run MOS PUP on A3000 with Mediator Busboard (with or without core logic card - means with connected or not connected pci slots)?
    Of course I know that Mediator is not supported, I tried to run MOS without pci cards just with CV64/3D but with no success.The latest verion of MOS even stuct in the first reset procedure, the older ones do a proper reset but freeze in booting mos.
    At least does anyone managed to run MOS PUP on any A3000? :-?
  • »02.07.06 - 10:22
    CLS2086
    Posts: 168 from 2005/8/25
    please use FFS or an older SFS 68k version,
    take the previous MOS PUP version (if you can find it), then copy "BOOT" directory.
    Go in DEVS/Monitor and check if it R/W/Execute for the CV64 and others.
    add "debugramdump file" just before the loader if you want to know more.
    Keep the Faith !
    VG 5000/A1000/500/500+/600/2000/1200PPC-GREX/1200PPC-ATEO/1200+1230-IVFPUSCSI/CD32/Pegasos 1 April1 G3/Pegasos 2 G4/ Ahtlon/K6-3/various funny machines too :-)
  • »03.07.06 - 13:24
    amipeg
    Strange is, that I was successfuly using the same MorphOS PUP installation on A4000/CPPC/CV64-3D before I switched to A3000 (scsi disk has the same fs etc).
    A3000 resets (with the MOS distribution prior to the latest version), boots and gives me the black screen and HDD led keeps shining forever. As I use the video-switch, I can see that CV-3D gives a signal - but only just the mentioned black screen.. :-(
  • »03.07.06 - 22:02
