Posts: 130 from 2005/10/12
@LawlessPPC
The A4000 I am using has both ide and scsi (fastlane interface) HDD's. I first tried staright from the CD-ROM and the scsi drive following the simple startup instructions. No joy.
I then repartitioned the scsi with SFS and copied the cd-rom to the low priority boot partition. I attempted to (manually) boot off the selected scsi partition. No joy.
I tried endless edits of the startup sequence - No joy
I tried boot from the ide/ CDRom combination - No joy.
I am now going to copy the contents of the PUP cd-rom to a bootable partition om the ide HDD and attempt to boot again.
The ide drive has the standard AOS ffs.
My completer setup is:-
Cyberstorm PPC/230e/060 with CS 64/3D, 18MB ram on A4000, 64MB ram on CS and 64MB on fastlane card.
The system works fine under OS3.9.
Update: Manually booting of the internal ide drive (ffs system) and guess what? MorphOS boots up without any changes to the startup-sequence!!
I need to create at least 16bit screen mode for ambient as only an 8-bit mode seems to be included, but at leasy I seem to be making progress.
[ Edited by TrevorDick on 2006/5/25 20:49 ]
[ Edited by TrevorDick on 2006/5/25 20:51 ]
