A4000T and no CD-ROM @ int. scsi-controller
    Markus_Bieler
    Posts: 19 from 2004/3/20
    Hi there,
    Even it is mentioned that the internal scsi-controller of the A4000T should work, I can't mount anything from the controller (scsi.device not found).
    Could I extract the scsi.device from the kickrom and put it into the devs drawer to use it via a mountlist?
    Markus
    :angel:
  • »06.03.06 - 20:49
    CLS2086
    Posts: 168 from 2005/8/25
    Did you use a real 'image' of your kickstart, or did you use the 'FakeRom' one ?
    Keep the Faith !
    VG 5000/A1000/500/500+/600/2000/1200PPC-GREX/1200PPC-ATEO/1200+1230-IVFPUSCSI/CD32/Pegasos 1 April1 G3/Pegasos 2 G4/ Ahtlon/K6-3/various funny machines too :-)
  • »07.03.06 - 09:15
    Markus_Bieler
    I use the real kick 40.070 from the A4000T. Floppy support does work, but not scsi.
    :angel:
  • »07.03.06 - 10:15
    DJBase
    Posts: 745 from 2003/4/6
    Same here, the internal SCSI never worked.
  • »07.03.06 - 10:20
    MorphOS_Team
    Posts: 10 from 2004/7/23
    The A4000t scsi device inside morphos "should" work
    but it wasn't tested for a long time...
    I assume it's only a HW detection problem and not
    a problem of the device itself.
    Please boot with your rom kickstart, so remove this
    <nokickstart> startup parameter.
    please check with <c:devlist> if scsi.device is
    there.
    if not, please do a <c:modlist> to check if your
    kickstart has a workbench.library, as the MorphOS
    A4000T detection only works through checking
    for a not existing workbench.library in the rom.
    Further informations can be retrieved through
    EDebugFlags="Init InitResident" and capturing
    the output with ramdebug or serial.
  • »07.03.06 - 14:03
    Markus_Bieler
    devlist gives following results:
    address version rev opencnt flags name
    0x08037D70 50 3 1 0x4 gameport.device
    0x08040BDC 50 11 30 0x4 timer.device
    0x080433A8 50 6 2 0x4 keyboard.device
    0x0804C3AC 50 26 7 0x4 input.device
    0x08055BC0 50 4 0 0x4 ramdrive.device
    0x08056110 40 1 3 0x4 trackdisk.device
    0x080685F0 50 11 8 0x4 console.device
    0x08072B04 50 21 0 0x24 scsi.device
    0x08072018 50 21 1 0x4 A4000/A1200 ATAPI Driver
    0x0807D5B4 50 18 5 0x4 cybppc.device
    0x085D3118 39 7 0 0x4 printer.device
    scsi.device is there, but I can't open scsi.device at ID4 (my CD-ROM) and also my HDs don't show up.
    Could this be due to the ffs on the HD at the A4000T_scsi-controller?
    [ Edited by Markus_Bieler on 2006/3/7 23:22 ]
    :angel:
  • »07.03.06 - 21:20
    MorphOS_Team
    no..has nothing to do with rdb.
    The MorphOS scsi.device is obviously there.
    Please try the debugging options and make a log.
  • »07.03.06 - 21:38
    Markus_Bieler
    logfiles are here
    http://mitglied.lycos.de/amiga1000/storage
    ascii or .lha
    Markus
    :angel:
  • »08.03.06 - 00:25
    CLS2086
    Hum, are you sure to have the good kickstart for A4000T ?
    Because A4000D don't have SCSI hardware, but a SCSI.Device that manage the IDE Hardware...
    What is the Scsi chip version and revision on your mobo ?
    Keep the Faith !
  • »08.03.06 - 14:40
    MorphOS_Team
    Well, the log shows that the morphos a4000t ncr device isn't initialized, so the board detection fails
    for some unknown reason. The source part there
    looks at least ok.
  • »08.03.06 - 15:46
    Markus_Bieler
    That means the device is there but the controller couldn't be
    found? Any suggestions for a work around?
    :angel:
  • »08.03.06 - 22:42
    Failure
    Posts: 9 from 2006/2/27
    I was able to get this to work by moving the workbench.library out of boot/extmodules. Before this I had the same results as you. Now, all of my SCSI and IDE drives work except for CD-ROM. Almost there!
    *edit* SCSI CD-ROM works now too. I must have been trying to use a coaster instead of a CD earlier...
    [ Edited by Failure on 2006/5/13 13:19 ]
    You can't spell evil without "vi"
    AMIX Wiki
  • »13.05.06 - 18:04
    Markus_Bieler
    Yes. yes. yes. :-) :-)
    Removing the workbench.library cured the scsi problem.
    A4000T scsi.device now working
    Thanx a lot "failure"
    Markus
    :angel:
  • »23.05.06 - 22:21
