PCI cards MOSPUP
    LawlessPPC
    Posts: 35 from 2006/1/22
    ok ive got a grex with vodoo3 3000 , sb128 and realtek 8139 10/100mb. Now how do i get the 3d to function on voodoo. Is there a sb128 driver available or is my only choice a SBLive card. The 8139 card which driver do i use I have seen someone on here using 1.
    Thanks in advance
  • »17.04.06 - 10:10
    CLS2086
    Posts: 168 from 2005/8/25
    the answer was done month ago, i'm sad that you don't read about my post...  :-?
    Voodoo3 3000 it works (if it doesn't take off the voodoo4.library and put a renamed copy of voodoo3.library (look in the WipeOut2097 thread...  :-? )
    sb128 no
    8139 depends of the card and chipset revision
    Keep the Faith !
    VG 5000/A1000/500/500+/600/2000/1200PPC-GREX/1200PPC-ATEO/1200+1230-IVFPUSCSI/CD32/Pegasos 1 April1 G3/Pegasos 2 G4/ Ahtlon/K6-3/various funny machines too  :-)
  • »17.04.06 - 14:15
    LawlessPPC
    I am sorry if my question has caused a problem and yes I read the metioned post before I posted. It just concerns me about renaming libraries. Just after your wipeout post no-one cometed or posted after to that to confirm. This is what I hoped would happen here.
    Regarding posts on Morphzone the search function doesnt work. Anyone got any ideas why not
  • »17.04.06 - 15:12
    Posts: 917 from 2004/1/24
    Well, the search function works for me (tm), though you have to enable javascript in your browser if you want to see more than the first page of returned results.
  • »17.04.06 - 15:47
