I need to alter the settings for resolution 1280x1024 at >8bit because the predefined ones don't work for my graphic card. I have a PicassoIV and this card is limited in 16/24 bit. When I try to lower the refresh rate modeedit decides to change the resolution :-/ On the 68k side with Picasso96 I had no problems creating a 1280x1024x16 resolution at 48Hz (yes, thats the lower limit of myTFT!) with its preference utility. I would like to use the same resolution setting with MorphOS too. I believe it should work but I have no idea how I can make it work.
Hi, go to the "screenmode" menu and change the pixelclock for the "Mode" you want.
Keep the Faith ! VG 5000/A1000/500/500+/600/2000/1200PPC-GREX/1200PPC-ATEO/1200+1230-IVFPUSCSI/CD32/Pegasos 1 April1 G3/Pegasos 2 G4/ Ahtlon/K6-3/various funny machines too Maybe one day a G4 AmigaONE when they will be debugged and without April...
