Posts: 168 from 2005/8/25
set bootdevice "bootdevice=dh0.2:"
"The true is out there..."
Retry without the " : " it should help.
; Bootdevice can be used to specify the MorphOS partition if you have more than one
; bootable partition and the MorphOS one doesn't have the highest boot priority. Remember
; to use partition names, not volume names! This option requires the 'bootdevice' keyword
; like in the example below:
; set bootdevice "bootdevice=DH1"
; Leave the var blank if you want to boot from the default boot partition!
and also why did you give a name with a dot to the partition ??
[ Edited by CLS2086 on 2006/4/2 20:36 ]
Keep the Faith !
VG 5000/A1000/500/500+/600/2000/1200PPC-GREX/1200PPC-ATEO/1200+1230-IVFPUSCSI/CD32/Pegasos 1 April1 G3/Pegasos 2 G4/ Ahtlon/K6-3/various funny machines too
